iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement
  1. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: step 1, image 1 of 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, Outer Base Plate: step 1, image 2 of 2
    • Place the computer monitor face down on a safe, harmless surface.
    • Using a Phillips #00 screw driver, remove the four 6.86 mm screws from the metal plate.
  2. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement: step 2, image 1 of 1
    • Remove the metal plate from bottom of the iMac G4.
    • The four screws do not completely separate from the metal plate.
  3. iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: step 3, image 1 of 2 iMac G4 15" 700 MHz EMC 1873 RAM SO-DIMM Replacement, RAM DIMM: step 3, image 2 of 2
    • Release the tabs on each side of the module by simultaneously pushing each tab away from the RAM.
    • These tabs lock the module in place and releasing them will cause the module to "pop" up.
    • Remove the RAM module from the iMac.
10 other people completed this guide.
Ryan Kozak
1,747 Reputation
3 Guides authored
Cal Poly, Team 5-32, Amido Fall 2011 Member of Cal Poly, Team 5-32, Amido Fall 2011
CPSU-AMIDO-F11S5G32
4 Members
16 Guides authored
2 Comments
Please correct the title, this is a 144 pin SODIMM, it is not a DIMM
The 168 pin DIMM is used in the internal socket.
Canadaram - Reply
Thanks For catching this Typo! :-)
Ben Capehart -
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 17
All Time: 5,795
