iMac G4 17 800 MHz EMC 1936 Airport Card Replacement
  1. iMac G4 17 800 MHz EMC 1936 Airport Card Replacement, Bottom Plate: step 1, image 1 of 1
    • Unplug all the cables from the computer, including the power cable. Lay the computer face-down, supporting the neck and base with a soft cloth under the screen.
  2. iMac G4 17 800 MHz EMC 1936 Airport Card Replacement: step 2, image 1 of 1
    • Loosen the four Phillips #0 screws.
  3. iMac G4 17 800 MHz EMC 1936 Airport Card Replacement: step 3, image 1 of 1
    • Carefully remove the base access panel.
7 other people completed this guide.
David Hunter
650 Reputation
4 Guides authored
Cal Poly, Team 21-22, Maness Fall 2011 Member of Cal Poly, Team 21-22, Maness Fall 2011
CPSU-MANESS-F11S21G22
4 Members
13 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 4,997
