iMac G5 17" Model A1058 Rear Panel Replacement
  1. iMac G5 17" Model A1058 Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
    • Lay the iMac display-side down on a flat surface.
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 17" Model A1058 Rear Panel Replacement: step 2, image 1 of 3 iMac G5 17" Model A1058 Rear Panel Replacement: step 2, image 2 of 3 iMac G5 17" Model A1058 Rear Panel Replacement: step 2, image 3 of 3
    • Lift the rear panel slightly from the bottom edge of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
15 other people completed this guide.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 28
All Time: 11,471
