iMac G5 17" Model A1144 Front Bezel Replacement
No estimate
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1Remove your front bezel to gain access to your iMac's internals.
Tool used on this step:Plastic Cards$2.99
Insert a plastic card up into the corner of the air vent slot at the top of the rear case.
Push the card toward the top of the iMac to release the front bezel latch.
Pull the front bezel away from the rear case.
Repeat this process for the other side of the front bezel.
Almost done!
