iMac G5 20" Model A1076 AirPort Extreme Replacement
Walter Galan
Walter Galan and 3 other contributors
Last updated on April 25, 2024
No estimate
Moderate
Introduction
Go to step 1
Easily replace your AirPort Extreme card to regain wireless connectivity.
Parts
Tools
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Show more…
iFixit earns commission when you buy through these links.
  1. iMac G5 20" Model A1076 AirPort Extreme Replacement, Rear Panel: step 1, image 1 of 1
    • Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
    • Loosen the three Phillips screws securing the rear panel to the iMac.
    • These screws are captive in the iMac. The center screw will stop turning after about 3.5 turns and the outer screws will stop turning after about 5.5 turns. Do not try to remove these screws from your iMac.
  2. iMac G5 20" Model A1076 AirPort Extreme Replacement: step 2, image 1 of 2 iMac G5 20" Model A1076 AirPort Extreme Replacement: step 2, image 2 of 2
    • Lift the rear panel slightly near the bottom of the iMac.
    • Pull the rear panel toward yourself and remove it from the iMac.
  3. iMac G5 20" Model A1076 AirPort Extreme Replacement, AirPort Extreme: step 3, image 1 of 1
    • Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
    • During reinstallation, insert the AirPort card such that the antenna side is nearest the center of the logic board.
  4. iMac G5 20" Model A1076 AirPort Extreme Replacement: step 4, image 1 of 1
    • Insert the flat end of a spudger between the body of the AirPort card and its antenna connector.
    • Push the spudger away from the AirPort card to disconnect the AirPort antenna.
    • When reassembling your iMac, be sure to insert the AirPort card the way it was before disassembly.
19 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 10
All Time: 19,745
