iMac G5 20" Model A1076 PRAM Battery Replacement
Introduction
Go to step 1Use this guide to replace your CR2032 PRAM battery.
Lay the iMac display-side down on a flat surface (putting a cloth under the screen to protect it from bumps).
Loosen the three Phillips screws securing the rear panel to the iMac.
Lift the AirPort card slightly by its plastic tab and pull it straight away from its socket.
Remove the two 5.5 mm T6 Torx screws securing the AirPort bracket to the logic board.
