iMac G5 20" Model A1145 RAM Replacement
  1. iMac G5 20" Model A1145 RAM Replacement, Access Door: step 1, image 1 of 1
    • Orient the iMac face-side down on a table with the bottom edge facing yourself.
    • Remove the two Phillips screws securing the access door to the bottom grille of your iMac.
    • The screws are captive in the access door.
    • Before beginning the repair, unplug the computer and press and hold the power switch for 20-30 seconds, to discharge internal capacitors.
  2. iMac G5 20" Model A1145 RAM Replacement: step 2, image 1 of 1
    • Remove the access door.
  3. iMac G5 20" Model A1145 RAM Replacement, RAM: step 3, image 1 of 1
    • Insert your fingers into the two RAM arms and pull both arms toward yourself to eject the RAM chip.
  4. iMac G5 20" Model A1145 RAM Replacement: step 4, image 1 of 1
    • Slide the RAM chip straight out of its socket.
    • Make sure both RAM arms are fully rotated outward before reinstalling your RAM chip.
13 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 21,260
