iMac Intel 21.5" EMC 2308 RAM Replacement
  1. iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: step 1, image 1 of 2 iMac Intel 21.5" EMC 2308 RAM Replacement, Access Door: step 1, image 2 of 2
    • Loosen the three Phillips screws securing the access door to the bottom edge of your iMac.
    • These screws will remain captive in the access door.
    • Remove the access door from your iMac.
    • During reassembly, fasten the access door loosely and align it with the pocket cut into the outer case of the iMac before fully tightening the screws.
  2. iMac Intel 21.5" EMC 2308 RAM Replacement, RAM: step 2, image 1 of 1
    • Use the sharp tip of a spudger to pull the black plastic RAM tabs out of the memory bay.
  3. iMac Intel 21.5" EMC 2308 RAM Replacement: step 3, image 1 of 2 iMac Intel 21.5" EMC 2308 RAM Replacement: step 3, image 2 of 2
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
111 other people completed this guide.
One Comment
There needs to be a little bit of important discucssion about getting the new RAM properly seated into the slots. Otherwise, great instructions!
Mary - Reply
Past 24 Hours: 8
Past 7 Days: 23
Past 30 Days: 109
All Time: 89,040
