iMac Intel 21.5" EMC 2544 Power Supply Replacement
  1. iMac Intel 21.5" EMC 2544 Power Supply Replacement, Display: step 1, image 1 of 1
    Tool used on this step:
    iMac Intel 21.5" Cardboard Service Wedge
    Buy
    • With the hinge free to move, the iMac will be unbalanced and hard to work on. Repairs can be completed as shown, but are faster and easier with an iMac service wedge.
    • If you are using the iFixit cardboard service wedge, follow these assembly directions to put it together.
    • Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
  2. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 2, image 2 of 2
    • Starting on the left of the display, near the power button, insert the iMac Opening Tool into the gap between the glass panel and the rear enclosure.
    • The hub on the iMac Opening Tool will keep you from pushing the wheel in too far. If using a different tool, insert no more than 3/8" into the display. Otherwise, you risk severing antenna cables and causing serious damage.
    • Be gentle! The glass may crack if pried too much. Use a hairdryer to heat the edges and loosen the tape if the room temperatures are low.
  3. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 3, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 3, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 3, image 3 of 3
    • Use the tool like a pizza cutter—roll it along through the gap, and it will cut the foam adhesive through the center.
    • Be sure to always push with the handle behind the cutting wheel. If you pull, the wheel might get pulled out of the handle.
    • Run the tool up along the left side of the display.
  4. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 4, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 4, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 4, image 3 of 3
    • Continue running the tool up around the top left corner.
  5. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 5, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 5, image 2 of 2
    • Cut the adhesive along the top left of the display.
  6. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 6, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 6, image 2 of 2
    • Continue along the top of the display.
    • You may want to run the tool back and forth through what you've already cut a few times, to ensure you get as much of the adhesive separated as possible.
  7. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 7, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 7, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 7, image 3 of 3
    • Push the tool around the top right corner of the display.
  8. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 8, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 8, image 2 of 2
    • Wheel the tool down along the right side of the display.
  9. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 9, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 9, image 2 of 2
    • Finish pushing the opening tool to the bottom of the right side of the display.
    • At this point, you'll want to run the tool back around the entire display, to ensure you cut as much adhesive as possible.
  10. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 10, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 10, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 10, image 3 of 3
    Plastic Cards
    $2.99
    Buy
    • While the opening tool cut most of the adhesive, the display will still be slightly adhered to the case. A plastic card will be necessary to free up the last of this adhesive.
    • Set the iMac face-up on a table.
    • Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
    • Be careful not to insert the plastic card more than 3/8", or you may damage internal components.
  11. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 11, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 11, image 2 of 2
    • Gently twist the plastic card sideways to create a gap between the display and frame.
    • Move slowly and be careful not to stress the display glass too much—you only need to make a gap of about 1/4".
  12. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 12, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 12, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 12, image 3 of 3
    • Slide the card toward the center of the display to cut any of the remaining adhesive along the top right corner of the iMac.
    • Be sure to stop before the iSight camera, or you may damage it.
  13. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 13, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 13, image 2 of 2
    • Wedge the plastic card into the top right corner once again and let it stay there to keep the adhesive from resettling.
  14. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 14, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 14, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 14, image 3 of 3
    • Insert a second plastic card into the gap between the display and frame located at the top left corner of the iMac.
  15. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 15, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 15, image 2 of 2
    • Gently twist the card upward, slightly increasing the space between the display and frame.
    • As with the other side, twist slowly to allow the adhesive time to separate, and be careful not to over-stress the display glass.
  16. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 16, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 16, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 16, image 3 of 3
    • Slide the plastic card toward the center, again stopping just before the iSight camera.
  17. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 17, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 17, image 2 of 2
    • Wedge the plastic card back into the top left corner.
  18. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 18, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 18, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 18, image 3 of 3
    • With both plastic cards inserted as shown near the corners, gently twist the cards sideways to increase the gap between display and case.
    • If there are any sections that seem to stick and won't separate, stop twisting and use one of the cards to cut the remaining adhesive.
    • Begin to lift the top of the display up from the frame.
    • Only lift the display a few inches—the display data and power cables are still connected to the logic board.
  19. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 19, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 19, image 2 of 2
    • While holding the display up with one hand, use the other hand to unplug the display power cable. Make sure that you pull the cable out from the plastic tab, and not by pulling on the color wires.
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
  20. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 20, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 20, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 20, image 3 of 3
    • Use the tip of a spudger to flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket.
  21. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 21, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 21, image 2 of 2
    • Lift the display up to a near-vertical position.
    • At this point there is still a strip of adhesive along the bottom of the display, that will hold the display to the frame like a hinge. You can loosen this adhesive by working the display up and down a few times.
  22. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 22, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 22, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 22, image 3 of 3
    • Be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply (boxed in red).
    • Grasp the small tab at the end of one of the bottom edge display adhesive strips and pull the adhesive toward the top of the iMac to remove it.
    • Repeat this step with the other adhesive strip and remove it.
    • If either adhesive strip breaks before it's removed, use a plastic card to slice through the remaining adhesive.
  23. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 23, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 23, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 23, image 3 of 3
    • Lift the display up from the frame and remove it from the iMac.
    • It may be necessary to slowly lift from one side, to peel against the remaining adhesive.
    • Be very careful handling the display—it's big, heavy, and made of glass.
    • During reassembly, head over to our display adhesive guide to install the new adhesive.
  24. iMac Intel 21.5" EMC 2544 Power Supply Replacement, Lower Support Bracket: step 24, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement, Lower Support Bracket: step 24, image 2 of 2
    • Remove the following five Phillips screws holding the lower support bracket in place:
    • Four 3.2 mm screws
    • One 1.7 mm screw
    • On at least some EMC 2544 machines, all five screws are the same size.
    • You may need to peel up the display adhesive lining the bottom edge of the iMac enclosure to access the screws.
  25. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 25, image 1 of 1
    • Remove the lower support bracket from the iMac enclosure.
  26. iMac Intel 21.5" EMC 2544 Power Supply Replacement, Hard Drive Brackets: step 26, image 1 of 1
    • Remove the following screws securing the hard drive bracket to the rear enclosure:
    • Two 21 mm T10 Torx screws from the left-hand hard drive bracket.
    • One 9 mm T10 Torx screw.
    • One 27 mm T10 Torx screw.
  27. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 27, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 27, image 2 of 2
    • Remove the left and right hard drive brackets from the iMac.
  28. iMac Intel 21.5" EMC 2544 Power Supply Replacement, Power Supply: step 28, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement, Power Supply: step 28, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement, Power Supply: step 28, image 3 of 3
    • The next few steps bring your hands close to the exposed face of the power supply. Do not touch the face of the power supply to avoid a high voltage shock from the many large capacitors attached to the board.
    • Use the tip of a spudger to push each side of the power button cable connector and gently "walk" it out of its socket.
  29. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 29, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 29, image 2 of 2
    • Gently push upward on each side of the power supply control cable connector with the tip of a spudger to gently "walk" it out of its socket.
  30. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 30, image 1 of 1
    • Remove the two 7.2 mm T10 screws securing the power supply to the rear enclosure.
  31. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 31, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 31, image 2 of 2
    • When working on the power supply, be very careful not to touch the capacitor leads or any exposed solder joints on the back of the power supply. Only handle the board by the edges.
    • Tilt the power supply forward.
  32. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 32, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 32, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 32, image 3 of 3
    • Pull the power supply slightly up and out from the rear enclosure.
    • Rotate the power supply counterclockwise, lifting the right side up about an inch higher than the left.
  33. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 33, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 33, image 2 of 2
    • Slide the power supply to the right to clear the screw posts on the rear enclosure.
  34. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 34, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 34, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 34, image 3 of 3
    • Rock the power supply forward and remove it from its recess in the rear enclosure.
    • Do not try to completely remove the power supply from the iMac yet—it is still connected to the logic board.
  35. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 35, image 1 of 2 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 35, image 2 of 2
    • Flip the top of the power supply towards you to access the DC power cable connection behind the logic board.
    • Squeeze the DC power cable connector tab and pull it straight out of its socket on the back of the logic board.
  36. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 36, image 1 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 36, image 2 of 3 iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 36, image 3 of 3
    • You may find it helpful to set the iMac down on its back on the table for the next couple of steps.
    • Use the flat end of a spudger to push the clip on the side of the AC inlet cable connector inward.
    • While holding on the release clip with the spudger, grasp the AC inlet cable, and pull the connector straight out of its socket.
  37. iMac Intel 21.5" EMC 2544 Power Supply Replacement: step 37, image 1 of 1
    • Remove the power supply from the iMac.
To reassemble your device, follow these instructions in reverse and use our Adhesive Strips Guide to reattach the display glass.
24 other people completed this guide.
Sam Goldheart
471,438 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
5 Comments
Is there anyway to swap the power inlet off this system?
corozc - Reply
how to check power supply. /?????
4k Cinema - Reply
You can use a wattmeter for a first diagnostic. If the PSU uses 0 then it's dead. It should use a couple of watts, when the Mac is turned off
Escudier Sébastien -
Pin out values for power supply ??
MARIO - Reply
After replacing the PSU, be careful that it is put back in place correctly. If it is not perfectly flat, it may slightly lift the screen which will not adhere properly
Escudier Sébastien - Reply
Past 24 Hours: 9
Past 7 Days: 26
Past 30 Days: 105
All Time: 19,528
