iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement, SATA Data and Power Cables: step 1, image 1 of 3 iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement, SATA Data and Power Cables: step 1, image 2 of 3 iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement, SATA Data and Power Cables: step 1, image 3 of 3
    • The SATA data connector has a clip that must be pressed to allow removal.
    • While pressing on the clip with your thumb, lift and disconnect the SATA data connector from its socket on the logic board.
  2. iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement: step 2, image 1 of 2 iMac Intel 21.5" EMC 2805 SATA Data and Power Cables Replacement: step 2, image 2 of 2
    • Grasp the hard drive power connector and gently pull it out of its socket on the logic board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 37
