Introduction
Reclaim your video chat capabilities, use this guide to replace the FaceTime camera cable on your 21.5" Retina 4K 2017 iMac.
Some images in this guide use a 2015 iMac, which has minor visual differences. These differences do not affect the repair procedure.
Before beginning any work on your iMac: Unplug the computer and press and hold the power button for ten seconds to discharge the power supply's capacitors.
Starting from the top right corner of the iMac, wedge a plastic card between the display and frame.
Hold the display with one hand while using your other hand to unplug the display power cable.
Use the tip of a spudger to flip down the metal retaining bracket on the camera cable.
To reassemble your device, follow these instructions in reverse.
