iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 1 of 2 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement, Display Assembly Cables: step 1, image 2 of 2
    • Lift the display up enough to have easy access to the connector, but not so much that you stretch the cables and stress their connections (about 8").
    • Hold the display with one hand while using your other hand to unplug the display power cable.
  2. iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 1 of 3 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 2 of 3 iMac Intel 21.5" Retina 4K Display Display Assembly Cables Replacement: step 2, image 3 of 3
    • Continuing to support the display with one hand, flip up the metal retaining bracket on the display data cable.
    • Carefully pull the display data cable from its socket on the logic board.
    • Be sure to pull the display data cable connector straight out of its socket, keeping it parallel to the motherboard, to avoid damaging it.
Evan Noronha
226,078 Reputation
168 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 7
Past 30 Days: 8
All Time: 409
