iMac Intel 24" EMC 2267 RAM Replacement
  1. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 1, image 1 of 1
    • Lay your iMac front side down on a table with the lower edge facing yourself.
    • Loosen the single Phillips screw PH#2 in the center of the access door.
    • This screw is captive in the access door.
    • Remove the access door from your iMac.
  2. iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 2, image 1 of 2 iMac Intel 24" EMC 2267 RAM Replacement, Note - most of this guide was taken from the info for: iMac Intel 20" EMC 2266: step 2, image 2 of 2
    • Use the sharp end of a spudger to pull the black plastic RAM tabs out of the memory bay. Formatting help
    • Pull the black plastic RAM tab away from your iMac to eject the RAM chip.
  3. iMac Intel 24" EMC 2267 RAM Replacement: step 3, image 1 of 1
    • Grab the RAM chip by its edges and pull it straight out of its slot.
    • If two RAM chips are installed, repeat this process for the other chip.
37 other people completed this guide.
johann beda
2,550 Reputation
15 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 47
All Time: 26,816
