iNet M1001 USB Port Replacement
  1. iNet M1001 USB Port Replacement, Back Cover: step 1, image 1 of 2 iNet M1001 USB Port Replacement, Back Cover: step 1, image 2 of 2
    • Remove the two 4.1 mm PH1 screws with a Philips screwdriver.
  2. iNet M1001 USB Port Replacement: step 2, image 1 of 2 iNet M1001 USB Port Replacement: step 2, image 2 of 2
    • Press the small suction cup on the back cover, and then pull the small suction cup to remove the back cover.
  3. iNet M1001 USB Port Replacement, USB Port: step 3, image 1 of 2 iNet M1001 USB Port Replacement, USB Port: step 3, image 2 of 2
    • Remove the two 3.8 mm PH1 screw with a Philips screwdriver.
  4. iNet M1001 USB Port Replacement: step 4, image 1 of 1
    • Remove the USB port from it's plastic housing.
  5. iNet M1001 USB Port Replacement: step 5, image 1 of 2 iNet M1001 USB Port Replacement: step 5, image 2 of 2
    • Desolder the white wire, and pull it off of the motherboard.
    • Check out this awesome guide for tips on soldering and desoldering.
Abdulateef Abola
401 Reputation
4 Guides authored
IUPUI, Team 4-1, Baechle Spring 2017 Member of IUPUI, Team 4-1, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G1
2 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 192
