iPad 2 GSM Front Facing Camera Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 2 GSM Front Facing Camera Replacement, Front Facing Camera: step 1, image 1 of 1
    • Remove the piece of tape highlighted in red.
    • Be careful not to damage the camera, microphone, or headphone jack ribbon cables as you remove the tape.
  2. iPad 2 GSM Front Facing Camera Replacement: step 2, image 1 of 1
    • Peel the front camera off the foam adhesive securing it to the rear panel.
  3. iPad 2 GSM Front Facing Camera Replacement: step 3, image 1 of 1
    • Pull the front facing camera cable out from the channel cut into the rear panel.
    • Remove the front facing camera from your iPad.
  4. iPad 2 GSM Front Facing Camera Replacement: step 4, image 1 of 2 iPad 2 GSM Front Facing Camera Replacement: step 4, image 2 of 2
    • Use a plastic opening tool to disconnect the microphone cable connector.
    • Remove the headphone jack/SIM slot from the device.
Andrew Optimus Goldheart
508,661 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,430 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 3
Past 30 Days: 3
All Time: 191
