You're viewing a previously published version of this guide.  View latest version
Older Newer
iPad 2 GSM LCD Assembly Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart and 3 other contributors
Last updated on November 22, 2019
No estimate
Moderate
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
Introduction
Go to step 1
Internal guide for removing LCD before logic board.
Tools
  1. iPad 2 GSM LCD Assembly Replacement, LCD Assembly: step 1, image 1 of 3 iPad 2 GSM LCD Assembly Replacement, LCD Assembly: step 1, image 2 of 3 iPad 2 GSM LCD Assembly Replacement, LCD Assembly: step 1, image 3 of 3
    • Carefully lay the LCD next to the rear panel.
    • Use a plastic opening tool to lift the display data cable lock upwards.
    • Pull the display data cable out of its socket.
    • Do not pull the connector upward as you disconnect it from its socket.
  2. iPad 2 GSM LCD Assembly Replacement: step 2, image 1 of 1
    • Remove the LCD assembly from the rear panel assembly.
508,838 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,527 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 194
