iPad 2 GSM LCD Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 2 GSM LCD Replacement, LCD: step 1, image 1 of 1
    • Remove the four 2.0 mm Phillips screws securing the LCD to the rear case.
  2. iPad 2 GSM LCD Replacement: step 2, image 1 of 2 iPad 2 GSM LCD Replacement: step 2, image 2 of 2
    • Lift the LCD from its long edge closest to the volume buttons and rotate it out of the rear case.
    • Lay the LCD on the front panel as seen in the second picture.
  3. iPad 2 GSM LCD Replacement: step 3, image 1 of 1
    • Use the edge of a plastic opening tool to flip up the metal retaining clip securing the display data cable to its socket on the logic board.
  4. iPad 2 GSM LCD Replacement: step 4, image 1 of 1
    • Pull the display data cable out of its socket on the logic board.
    • Do not lift upward on the display data cable connector as you disconnect it.
  5. iPad 2 GSM LCD Replacement: step 5, image 1 of 1
    • Remove the LCD assembly from the iPad 2.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 432
