iPad 2 GSM Logic Board Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad 2 GSM Logic Board Replacement, Logic Board: step 1, image 1 of 3 iPad 2 GSM Logic Board Replacement, Logic Board: step 1, image 2 of 3 iPad 2 GSM Logic Board Replacement, Logic Board: step 1, image 3 of 3
    • If present, remove the piece of tape covering the end of the dock connector cable.
    • Use the edge of a plastic opening tool to carefully pry the dock connector cable's connector up from its socket on the logic board.
    • Peel the dock connector ribbon cable off the rear panel.
  2. iPad 2 GSM Logic Board Replacement: step 2, image 1 of 1
    • Place the prying tool beneath the 4 wires on the end of the connector and gently pry the speaker cable connector straight up from its socket on the logic board. Do not pry from the opposite end of the connector as this will break the 4 solder points on the underside of the socket and will require a microsolder repair.
  3. iPad 2 GSM Logic Board Replacement: step 3, image 1 of 3 iPad 2 GSM Logic Board Replacement: step 3, image 2 of 3 iPad 2 GSM Logic Board Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to flip up the retainer securing the upper component board cable connector to its socket on the logic board.
    • Pull the connector away from its socket on the logic board.
    • Do not lift the cable upward as you disconnect it.
  4. iPad 2 GSM Logic Board Replacement: step 4, image 1 of 2 iPad 2 GSM Logic Board Replacement: step 4, image 2 of 2
    • Remove the two 2.1 mm Phillips screws securing the logic board bracket to the rear case near the digitizer cable socket.
    • Remove the logic board bracket from the rear case.
  5. iPad 2 GSM Logic Board Replacement: step 5, image 1 of 1
    • Remove the four 2.6 mm Phillips screws securing the logic and communications boards to the rear panel.
  6. iPad 2 GSM Logic Board Replacement: step 6, image 1 of 2 iPad 2 GSM Logic Board Replacement: step 6, image 2 of 2
    • Use a plastic opening tool to gently pry the logic board up from the rear case.
    • The logic board is adhered to the rear case; work slowly and uniformly to peel up the glue without damaging the board.
  7. iPad 2 GSM Logic Board Replacement: step 7, image 1 of 1
    • Lift the logic board out from the rear case, and rotate it slightly toward the battery.
    • Do not try to completely remove the logic board. There are still three antenna cables attached to it.
Andrew Optimus Goldheart
508,667 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,446 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 4
All Time: 222
