iPad 2 Touch Screen Replacement Video tutorial
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Video Overview
  1. iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: step 1, image 1 of 2 iPad 2 Touch Screen Replacement Video tutorial, Front Panel Assembly: step 1, image 2 of 2
    • Use the edge of a plastic opening tool to carefully flip up the retaining flaps on the two digitizer ribbon cable ZIF sockets.
    • Be sure you are prying up on the hinged retaining flaps, not the sockets themselves.
    • The retaining flaps are highlighted in red in the second picture.
  2. iPad 2 Touch Screen Replacement Video tutorial: step 2, image 1 of 2 iPad 2 Touch Screen Replacement Video tutorial: step 2, image 2 of 2
    • Use the edge of a plastic opening tool to peel the digitizer cable off the shields on the logic board.
    • Carefully pull the digitizer cable off the adhesive securing it to the side of the rear case.
  3. iPad 2 Touch Screen Replacement Video tutorial: step 3, image 1 of 1
    • Pull the digitizer ribbon cable straight out of its two sockets on the logic board.
  4. iPad 2 Touch Screen Replacement Video tutorial: step 4, image 1 of 2 iPad 2 Touch Screen Replacement Video tutorial: step 4, image 2 of 2
    • In order to remove the front panel assembly, the ribbon cable needs to slide out between the case and the LCD. You'll need to move the LCD to make some room.
    • Be very careful when moving the LCD, and do not attempt to remove it from the iPad—its cable will remain connected while it is rotated over.
    • Lift the LCD from its long edge farthest from the digitizer cable and gently flip it toward the rear case—like closing a book.
    • While holding the LCD up, gently slide the front panel away from the iPad. Be careful not to snag the digitizer cable on the rear case or LCD.
    • Set the LCD back into the body for safekeeping.
4 other people completed this guide.
ZFix
195,994 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
329 Members
1,452 Guides authored
1 Guide Comment
We replaced the screen successfully and it turns on all looks beautiful except the touch screen isn’t working at all—any thoughts? We are beginners
shelley fiedler - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 4,552
