iPad 3 Wi-Fi Front Panel Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPad 3 Wi-Fi Front Panel Assembly Replacement, Front Panel Assembly: step 1, image 1 of 1
    • Remove the four 2 mm Phillips #00 screws securing the LCD to the aluminum frame.
  2. iPad 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 1 of 3 iPad 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 2 of 3 iPad 3 Wi-Fi Front Panel Assembly Replacement: step 2, image 3 of 3
    • Using a plastic opening tool or a spudger, lift the right edge of the LCD out of the iPad.
    • Rotate the LCD along its left edge and lay it down on top of the front panel.
    • Be careful as you move the LCD. The ribbon cable is fragile and may break if it is flexed too much.
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 21
All Time: 229
