iPad 4 CDMA Home Button Control Board Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPad 4 CDMA Home Button Control Board Replacement, Home Button Control Board: step 1, image 1 of 1
    • Remove the two 2.1 mm Phillips #00 Phillips screws securing the home button control board to the home button mounting bracket.
  2. iPad 4 CDMA Home Button Control Board Replacement: step 2, image 1 of 2 iPad 4 CDMA Home Button Control Board Replacement: step 2, image 2 of 2
    • Wedge the flat edge of a plastic opening tool in between the right end of the home button control board and the home button mounting bracket.
    • Depress the plastic opening tool downwards to pry the adhesive securing the home button control board from the home button mounting bracket.
    • Repeat the procedure to release the adhesive underneath the left end of the home button control board.
  3. iPad 4 CDMA Home Button Control Board Replacement: step 3, image 1 of 1
    • Lift and remove the home button control board up off the home button mounting bracket.
  4. iPad 4 CDMA Home Button Control Board Replacement: step 4, image 1 of 2 iPad 4 CDMA Home Button Control Board Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Use the flat edge of a spudger to scrape the old adhesive off the bottom right corner of the front panel assembly.
    • If necessary, gently peel the old adhesive with a pair of tweezers.
  5. iPad 4 CDMA Home Button Control Board Replacement: step 5, image 1 of 2 iPad 4 CDMA Home Button Control Board Replacement: step 5, image 2 of 2
    • Gently place the home button control board on top of the home button mounting bracket.
    • Make sure the home button control board is lined up with the bottom of the home button mounting bracket.
  6. iPad 4 CDMA Home Button Control Board Replacement: step 6, image 1 of 1
    • Insert the two 2.1 mm Phillips #00 Phillips screws back into the home button control board to secure it against the home button mounting bracket.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 216
