Introduction
Use this guide to install adhesive strips on a replacement front panel.
Only for use with NEW front panel assemblies.
In the following steps, you will be placing the remaining pieces of adhesive on the front panel.
Do not peel the clear backing off the strips just yet.
Place the bridge shaped adhesive strip between the top edge of the inner frame of the front panel and the camera mounting bracket.
Smooth the strip down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
Tool used on this step:Tweezers$4.99
Use a pair of tweezers to peel the clear backing up off the adhesive strip directly underneath the home button ribbon cable.
Lay the home button ribbon cable down on the adhesive strip and smooth the cable down from the center out, taking care to not trap any air bubbles between the strip and the front panel.
You're finished.
You're finished.
33 other people completed this guide.
One Comment
Conclusion:
“To reassemble your device, follow these instructions in reverse order. “
Something goes wrong here…
