iPad 7 Right Speaker Replacement
  1. iPad 7 Right Speaker Replacement, Heat the left edge: step 1, image 1 of 1
    • Heat an iOpener and apply it to the left edge of the device for two minutes.
  2. iPad 7 Right Speaker Replacement, Screen removal information: step 2, image 1 of 3 iPad 7 Right Speaker Replacement, Screen removal information: step 2, image 2 of 3 iPad 7 Right Speaker Replacement, Screen removal information: step 2, image 3 of 3
    • While you're waiting for the adhesive to loosen, note the following areas that are sensitive to prying:
    • Front camera
    • Antennas
    • Display cables
  3. iPad 7 Right Speaker Replacement, Anti-Clamp instructions: step 3, image 1 of 3 iPad 7 Right Speaker Replacement, Anti-Clamp instructions: step 3, image 2 of 3 iPad 7 Right Speaker Replacement, Anti-Clamp instructions: step 3, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Place an object under your iPad so it rests level between the suction cups.
    • Position the suction cups near the middle of the left edge—one on the top, and one on the bottom.
    • Hold the bottom of the Anti-Clamp steady and firmly press down on the top cup to apply suction.
    • If you find that the surface of your iPad is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  4. iPad 7 Right Speaker Replacement: step 4, image 1 of 3 iPad 7 Right Speaker Replacement: step 4, image 2 of 3 iPad 7 Right Speaker Replacement: step 4, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  5. iPad 7 Right Speaker Replacement: step 5, image 1 of 2 iPad 7 Right Speaker Replacement: step 5, image 2 of 2
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • If your screen isn't getting hot enough, you can use a hair dryer to heat along the left edge of the iPad.
    • For complete instructions on how to use a hair dryer, check out this guide.
    • Insert an opening pick under the digitizer when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next step.
  6. iPad 7 Right Speaker Replacement, Insert an opening pick: step 6, image 1 of 3 iPad 7 Right Speaker Replacement, Insert an opening pick: step 6, image 2 of 3 iPad 7 Right Speaker Replacement, Insert an opening pick: step 6, image 3 of 3
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Once the screen is warm to touch, apply a suction handle to the left edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the digitizer and the frame.
    • Insert an opening pick into the gap between the digitizer and the frame.
  7. iPad 7 Right Speaker Replacement, Separate the left adhesive: step 7, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the left adhesive: step 7, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the left adhesive: step 7, image 3 of 3
    • Insert a second opening pick into the gap you just created.
    • Slide the pick toward the bottom-left corner of the device to separate the adhesive.
    • Leave the pick in the bottom-left corner to prevent the adhesive from re-sealing.
    • Don't worry if you can see the opening pick through the digitizer—just pull the pick out. The LCD screen shouldn't be damaged, but you risk leaving behind hard-to-clean adhesive.
  8. iPad 7 Right Speaker Replacement: step 8, image 1 of 3 iPad 7 Right Speaker Replacement: step 8, image 2 of 3 iPad 7 Right Speaker Replacement: step 8, image 3 of 3
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad to continue separating the adhesive.
  9. iPad 7 Right Speaker Replacement: step 9, image 1 of 3 iPad 7 Right Speaker Replacement: step 9, image 2 of 3 iPad 7 Right Speaker Replacement: step 9, image 3 of 3
    • Slide the first opening pick towards the top-left corner of the device to separate the adhesive.
    • Leave the pick in the top-left corner to prevent the adhesive from re-sealing.
  10. iPad 7 Right Speaker Replacement, Heat the top edge: step 10, image 1 of 1
    • Heat an iOpener and apply it to the top edge of the device for two minutes.
  11. iPad 7 Right Speaker Replacement, Separate the top left adhesive: step 11, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the top left adhesive: step 11, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the top left adhesive: step 11, image 3 of 3
    • Rotate the pick around the top-left corner of the device to separate the adhesive.
  12. iPad 7 Right Speaker Replacement, Separate the top adhesive: step 12, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the top adhesive: step 12, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the top adhesive: step 12, image 3 of 3
    • Slide the opening pick along the top edge of the device, stopping just before you reach the front camera.
    • Avoid sliding the pick over the front camera, as you may damage the lens. The following steps will show how to prevent this.
  13. iPad 7 Right Speaker Replacement: step 13, image 1 of 3 iPad 7 Right Speaker Replacement: step 13, image 2 of 3 iPad 7 Right Speaker Replacement: step 13, image 3 of 3
    • Pull the pick out until only the tip is between the digitizer and the frame.
    • Slide the pick above the front camera to separate the adhesive.
    • Leave the pick near the right side of the front camera before continuing.
  14. iPad 7 Right Speaker Replacement: step 14, image 1 of 3 iPad 7 Right Speaker Replacement: step 14, image 2 of 3 iPad 7 Right Speaker Replacement: step 14, image 3 of 3
    • Re-insert the pick and slide it towards the top-right corner of the device to completely separate the top adhesive.
    • Leave the pick in the top-right corner to prevent the adhesive from re-sealing.
  15. iPad 7 Right Speaker Replacement, Heat the right edge: step 15, image 1 of 1
    • Heat an iOpener and apply it to the right edge of the device for two minutes.
  16. iPad 7 Right Speaker Replacement, Separate the top right adhesive: step 16, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the top right adhesive: step 16, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the top right adhesive: step 16, image 3 of 3
    • Rotate the pick around the top-right corner of the device to separate the adhesive.
  17. iPad 7 Right Speaker Replacement, Separate the right adhesive: step 17, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the right adhesive: step 17, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the right adhesive: step 17, image 3 of 3
    • Insert a new opening pick and slide it to the middle of the iPad's right edge.
    • The display cables are located approximately halfway from the bottom of the iPad. Stop sliding once you reach three inches from the bottom of the iPad.
  18. iPad 7 Right Speaker Replacement, Heat the bottom edge: step 18, image 1 of 1
    • Heat an iOpener and apply it to the bottom edge of the device for two minutes.
  19. iPad 7 Right Speaker Replacement, Separate the bottom left adhesive: step 19, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the bottom left adhesive: step 19, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the bottom left adhesive: step 19, image 3 of 3
    • Slide the bottom-left pick to the bottom-left corner to separate the adhesive.
    • Don't fully rotate the pick around the corner, as you may damage the antenna.
    • Leave the pick in the bottom-left corner before moving to the next step.
  20. iPad 7 Right Speaker Replacement, Separate the bottom adhesive: step 20, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the bottom adhesive: step 20, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the bottom adhesive: step 20, image 3 of 3
    • Insert a new opening pick into the gap you just created on the bottom edge of the iPad.
    • Slide the pick over the antenna, stopping just before the home button.
    • Only slide the pick towards the home button and not away from it, as you may damage the antenna.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-left corner.
    • Leave the pick to the left of the home button before continuing.
  21. iPad 7 Right Speaker Replacement: step 21, image 1 of 3 iPad 7 Right Speaker Replacement: step 21, image 2 of 3 iPad 7 Right Speaker Replacement: step 21, image 3 of 3
    • Insert an opening pick into the gap you just created.
    • Slide the pick underneath the home button and towards the bottom-right corner, making sure only the tip is between the digitizer and the frame.
    • Only insert the pick up to 1 mm to avoid damaging the right antenna.
  22. iPad 7 Right Speaker Replacement: step 22, image 1 of 3 iPad 7 Right Speaker Replacement: step 22, image 2 of 3 iPad 7 Right Speaker Replacement: step 22, image 3 of 3
    • Re-insert the pick and slide it towards the home button to completely separate the bottom adhesive.
    • If you need to slide the pick over this section again, remove and re-insert it at the bottom-right corner.
    • Leave the pick to the right of the home button before continuing.
  23. iPad 7 Right Speaker Replacement, Heat the right edge: step 23, image 1 of 1
  24. iPad 7 Right Speaker Replacement: step 24, image 1 of 2 iPad 7 Right Speaker Replacement: step 24, image 2 of 2
    • Be very careful with this step. Take your time, ensure the adhesive is hot and soft, and make sure you separated all of the adhesive with a pick. Don't be afraid to stop and reheat.
    • Twist the two opening picks on the left corners of the iPad to lift the digitizer slightly, separating the the last of the adhesive in the process.
    • If there's a significant amount of resistance, reheat the edges and work along them with an opening pick.
  25. iPad 7 Right Speaker Replacement: step 25, image 1 of 2 iPad 7 Right Speaker Replacement: step 25, image 2 of 2
    • Lift the left edge of the digitizer upwards to further separate the adhesive along the right edge of the iPad.
  26. iPad 7 Right Speaker Replacement, Separate the right adhesive: step 26, image 1 of 3 iPad 7 Right Speaker Replacement, Separate the right adhesive: step 26, image 2 of 3 iPad 7 Right Speaker Replacement, Separate the right adhesive: step 26, image 3 of 3
    • While supporting the digitizer, slide an opening pick between the two display cables to separate the last of the adhesive.
  27. iPad 7 Right Speaker Replacement: step 27, image 1 of 2 iPad 7 Right Speaker Replacement: step 27, image 2 of 2
    • Once all of the adhesive has been separated, open the digitizer like a book and rest it parallel to the iPad.
    • During reassembly, clean the remaining adhesive from the frame—and the digitizer if you're re-using it—with isopropyl alcohol. Replace the adhesive with our adhesive strips or pre-cut adhesive cards.
    • Be mindful of the display cables when reassembling the device. Make sure they are folded properly underneath the LCD screen to prevent any damage.
  28. iPad 7 Right Speaker Replacement, Remove the LCD: step 28, image 1 of 2 iPad 7 Right Speaker Replacement, Remove the LCD: step 28, image 2 of 2
    Magnetic Project Mat
    $19.95
    Buy
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the LCD to the frame.
    • Remove any tape obscuring the LCD screws.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  29. iPad 7 Right Speaker Replacement, Flip the LCD over: step 29, image 1 of 3 iPad 7 Right Speaker Replacement, Flip the LCD over: step 29, image 2 of 3 iPad 7 Right Speaker Replacement, Flip the LCD over: step 29, image 3 of 3
    • Don't attempt to fully remove the LCD during this step, as it's still connected by several cables at the home button end.
    • Only lift the LCD from the front-facing camera end.
    • Use the flat end of a spudger to pry the LCD out of its recess just enough to grab it with your fingers.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the frame.
    • Lay the LCD down onto a clean, soft, lint-free surface to allow access to the display cables.
  30. iPad 7 Right Speaker Replacement, Disconnect the battery: step 30, image 1 of 2 iPad 7 Right Speaker Replacement, Disconnect the battery: step 30, image 2 of 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the battery connector to the logic board.
  31. iPad 7 Right Speaker Replacement, Battery connector information: step 31, image 1 of 3 iPad 7 Right Speaker Replacement, Battery connector information: step 31, image 2 of 3 iPad 7 Right Speaker Replacement, Battery connector information: step 31, image 3 of 3
    • These photos show what the battery connector looks like underneath the logic board. Use these photos as a reference while you safely disconnect the battery.
    • Notice that the battery connector has cantilever springs on the logic board that press against the battery contact pads. Since both the logic board and battery are glued down, you'll need to slide something thin and flexible between the contact points to disconnect the battery.
  32. iPad 7 Right Speaker Replacement, Disconnect the battery: step 32, image 1 of 3 iPad 7 Right Speaker Replacement, Disconnect the battery: step 32, image 2 of 3 iPad 7 Right Speaker Replacement, Disconnect the battery: step 32, image 3 of 3
    • Be careful when you isolate the battery using a battery blocker. The battery contacts are easily bent or broken, resulting in irreversible damage.
    • Ensure that the iFixit logo on the battery blocker is facing up.
    • Slide the battery blocker underneath the logic board's battery connector at a 35 degree angle.
    • Don't push the battery blocker underneath the connector with excessive force. If you're having trouble fitting the battery blocker underneath the logic board, you can try using a playing card to disconnect the battery instead.
    • The battery blocker or playing card ideally should slide under the logic board without encountering any blockages. After insertion, it should rest at about a 15 degree angle.
    • Leave the battery blocker in place as you work.
  33. iPad 7 Right Speaker Replacement, Unfasten the display cable bracket: step 33, image 1 of 2 iPad 7 Right Speaker Replacement, Unfasten the display cable bracket: step 33, image 2 of 2
    • Use a Phillips screwdriver to remove the three 1.4 mm-long screws securing the display cable bracket.
  34. iPad 7 Right Speaker Replacement, Remove the display cable bracket: step 34, image 1 of 2 iPad 7 Right Speaker Replacement, Remove the display cable bracket: step 34, image 2 of 2
    • Remove the display cable bracket.
  35. iPad 7 Right Speaker Replacement, Disconnect the LCD: step 35, image 1 of 2 iPad 7 Right Speaker Replacement, Disconnect the LCD: step 35, image 2 of 2
    • Use the flat end of a spudger to disconnect the LCD cable by lifting straight up on the press connector.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  36. iPad 7 Right Speaker Replacement, Remove the LCD: step 36, image 1 of 2 iPad 7 Right Speaker Replacement, Remove the LCD: step 36, image 2 of 2
    • Remove the LCD completely and rest it face down on a clean, soft, lint-free surface.
  37. iPad 7 Right Speaker Replacement, Disconnect the home button: step 37, image 1 of 2 iPad 7 Right Speaker Replacement, Disconnect the home button: step 37, image 2 of 2
    Buy
    • Use a pair of tweezers to peel off the tape covering the home button cable ZIF connector.
  38. iPad 7 Right Speaker Replacement: step 38, image 1 of 2 iPad 7 Right Speaker Replacement: step 38, image 2 of 2
    • Use a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the home button cable ZIF connector.
  39. iPad 7 Right Speaker Replacement: step 39, image 1 of 2 iPad 7 Right Speaker Replacement: step 39, image 2 of 2
    • Use a pair of tweezers to pull the home button ribbon cable straight out of the ZIF connector.
  40. iPad 7 Right Speaker Replacement, Disconnect the display cables: step 40, image 1 of 3 iPad 7 Right Speaker Replacement, Disconnect the display cables: step 40, image 2 of 3 iPad 7 Right Speaker Replacement, Disconnect the display cables: step 40, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the two digitizer cable press connectors.
    • To avoid damaging your iPad, pry only on the connectors themselves, not on the socket on the logic board.
  41. iPad 7 Right Speaker Replacement, Remove the vibration isolator: step 41, image 1 of 3 iPad 7 Right Speaker Replacement, Remove the vibration isolator: step 41, image 2 of 3 iPad 7 Right Speaker Replacement, Remove the vibration isolator: step 41, image 3 of 3
    • Use the flat end of a spudger to pry up the vibration isolator near the bottom-right corner of the device.
    • Take care not to puncture or tear the home button ribbon cable.
    • Remove the vibration isolator.
  42. iPad 7 Right Speaker Replacement: step 42, image 1 of 2 iPad 7 Right Speaker Replacement: step 42, image 2 of 2
    • The home button cable is secured with some light adhesive.
    • Use a pair of tweezers to peel the home button cable away from the frame.
  43. iPad 7 Right Speaker Replacement, Remove the front panel assembly: step 43, image 1 of 3 iPad 7 Right Speaker Replacement, Remove the front panel assembly: step 43, image 2 of 3 iPad 7 Right Speaker Replacement, Remove the front panel assembly: step 43, image 3 of 3
    Polyimide Tape
    $9.99
    Buy
    • Remove the front panel assembly.
    • Use an opening pick to cut away any residual adhesive that may still be connecting the front panel assembly to the frame.
    • If you experience "ghost" or "phantom" touch input issues with your new display, this can be resolved by adding a layer of very thin insulating tape, such as Kapton (polyimide) tape, to the highlighted areas on the back of the panel. iFixit replacement digitizers come with the proper insulation and should not require the addition of any tape.
    • Without the proper insulation, these areas of the digitizer can ground out against other components, causing touch input malfunction.
    • The insulation is not visible to the naked eye, and is different from the foam dust barrier strips found on many iPads.
    • During reassembly, before installing a display, remove any remaining adhesive from the iPad, and clean the glued areas with high concentration isopropyl alcohol (90% or greater) and a lint-free cloth. This helps prep the iPad for fresh adhesive and ensures that it will bond properly.
    • Test your iPad's functions and install pre-cut adhesive strips to the back of the display using our display adhesive application guide before sealing it up.
  44. iPad 7 Right Speaker Replacement, Disconnect the right antenna: step 44, image 1 of 2 iPad 7 Right Speaker Replacement, Disconnect the right antenna: step 44, image 2 of 2
    • Insert the pointed end of a spudger under the right antenna cable and lift straight up to disconnect it.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  45. iPad 7 Right Speaker Replacement, Remove the right antenna: step 45, image 1 of 2 iPad 7 Right Speaker Replacement, Remove the right antenna: step 45, image 2 of 2
    • Peel up the right antenna cable.
    • Grip the antenna cable by the cable itself and not at its connector. Pulling coaxial cables by their connectors can break them.
  46. iPad 7 Right Speaker Replacement: step 46, image 1 of 2 iPad 7 Right Speaker Replacement: step 46, image 2 of 2
    • Use a Phillips screwdriver to remove the three screws securing the right antenna.
    • One 2.3 mm-long screw
    • Two 1.4 mm-long screws
  47. iPad 7 Right Speaker Replacement: step 47, image 1 of 3 iPad 7 Right Speaker Replacement: step 47, image 2 of 3 iPad 7 Right Speaker Replacement: step 47, image 3 of 3
    • The antenna cable is anchored to the speaker with a small metal bracket. The bracket is permanently crimped to the antenna and adhered to the speaker enclosure. The adhesive must be severed in order to extract the antenna.
    • Carefully insert an opening pick between the speaker enclosure and the bracket.
    • Slide the pick toward the charging port to cut the adhesive.
    • Push the bracket away from the speaker until it clears the tape underneath.
  48. iPad 7 Right Speaker Replacement: step 48, image 1 of 3 iPad 7 Right Speaker Replacement: step 48, image 2 of 3 iPad 7 Right Speaker Replacement: step 48, image 3 of 3
    • Insert an opening pick between the antenna and speaker assembly.
    • Slide the opening pick underneath the antenna to cut the foam adhesive.
    • Remove the right antenna.
  49. iPad 7 Right Speaker Replacement, Disconnect the left antenna cable: step 49, image 1 of 2 iPad 7 Right Speaker Replacement, Disconnect the left antenna cable: step 49, image 2 of 2
    • Insert the pointed end of a spudger under the left antenna cable and lift straight up to disconnect it.
  50. iPad 7 Right Speaker Replacement: step 50, image 1 of 3 iPad 7 Right Speaker Replacement: step 50, image 2 of 3 iPad 7 Right Speaker Replacement: step 50, image 3 of 3
    • Peel the left antenna cable away from the rear case, along the bottom edge of the iPad.
    • Fold the left antenna cable out of the way.
  51. iPad 7 Right Speaker Replacement, Disconnect the right speaker: step 51, image 1 of 3 iPad 7 Right Speaker Replacement, Disconnect the right speaker: step 51, image 2 of 3 iPad 7 Right Speaker Replacement, Disconnect the right speaker: step 51, image 3 of 3
    Buy
    • Use a pair of tweezers or your fingernail to peel up the tape covering the speaker connectors.
    • You can either completely remove the tape or stop when you can access the right speaker ZIF connector.
  52. iPad 7 Right Speaker Replacement: step 52, image 1 of 2 iPad 7 Right Speaker Replacement: step 52, image 2 of 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the right speaker cable ZIF connector.
  53. iPad 7 Right Speaker Replacement: step 53, image 1 of 2 iPad 7 Right Speaker Replacement: step 53, image 2 of 2
    • Use a pair of tweezers to carefully pull the right speaker cable straight out of the ZIF connector.
  54. iPad 7 Right Speaker Replacement, Remove the right speaker: step 54, image 1 of 2 iPad 7 Right Speaker Replacement, Remove the right speaker: step 54, image 2 of 2
    • Use a Phillips screwdriver to remove the 2.3 mm-long screw securing the right speaker.
  55. iPad 7 Right Speaker Replacement: step 55, image 1 of 2 iPad 7 Right Speaker Replacement: step 55, image 2 of 2
    • Carefully peel the LCD buffer tape away from of the rear case.
  56. iPad 7 Right Speaker Replacement: step 56, image 1 of 3 iPad 7 Right Speaker Replacement: step 56, image 2 of 3 iPad 7 Right Speaker Replacement: step 56, image 3 of 3
    • Insert the flat end of a spudger into the groove in the speaker housing, near the corner of the rear case.
    • Push the speaker away from the rear case.
    • Push the speaker out from underneath the shelf on the rear case.
  57. iPad 7 Right Speaker Replacement: step 57, image 1 of 1
    • Remove the right speaker.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad 7 Answers community for help.
Alex Diaz-Kokaisl
129,318 Reputation
600 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,058 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 12
All Time: 161
