Ricoh Super 8 800z Eyepiece Adjuster Replacement
  1. Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: step 1, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: step 1, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: step 1, image 3 of 3
    • Remove the rubber covering from the eyepiece by slowly pulling down on the cover from any direction.
  2. Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 2, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 2, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 2, image 3 of 3
    • Use Phillips #000 screwdriver to remove the three screws around the eyepiece lens.
    • Remove the metal plate from the eyepiece.
  3. Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 3, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 3, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 3, image 3 of 3
    • Turn the adjustment ring counter clockwise until it is as close to the lens as it will go.
  4. Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 4, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 4, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 4, image 3 of 3
    • Remove the screw on top of the back panel of the camera using a Phillips #000 screwdriver.
    • Use a plastic opening tool to lift the plastic covering to reveal a screw underneath it.
  5. Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 5, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 5, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 5, image 3 of 3
    • Continue to hold the plastic covering back with the plastic opening tool.
    • Use a #1 flathead screwdriver to remove screw in the oval opening beside the eyepiece. Be careful not to drop the screw into the camera body.
  6. Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 6, image 1 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 6, image 2 of 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: step 6, image 3 of 3
    • Slide the eyepiece adjuster out of the camera body.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 334
