iPad Mini 2 Wi-Fi Front Panel Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: step 1, image 1 of 2 iPad Mini 2 Wi-Fi Front Panel Replacement, Front Panel: step 1, image 2 of 2
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  2. iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 1 of 3 iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 2 of 3 iPad Mini 2 Wi-Fi Front Panel Replacement: step 2, image 3 of 3
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  3. iPad Mini 2 Wi-Fi Front Panel Replacement: step 3, image 1 of 1
    • Lift and remove the front panel from the iPad.
10 other people completed this guide.
Sam Goldheart
475,282 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,829 Guides authored
2 Guide Comments
I'll give this quide a 3/5. The problem is the end where you just say reverse the steps. That is an easy out that too many people use. There are important things to do when re-assembling that are not pointed out that may come back to bite you just attempting to reverse the steps. I do like the stepped pictures showing before and after views. Overall the process is not that bad other than removing the broken glass which breaks a lot more as you go. A hair dryer on high worked fine for warming up the glue, you just need to be aware of cleaning the area of glass bits before turning it on. Glad I didn't pay somebody big bucks to do this job.
italternatives - Reply
Due reassebling its really important to bend the digitizer cable with a spudger inside the case. If you just press the Front down the cable will be between adhensive and case. So near the home button, it won't fit very well!!
itf7o - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 14
All Time: 6,668
