iPad Mini 3 Left Antenna Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPad Mini 3 Left Antenna Cable Replacement, Left Antenna Cable: step 1, image 1 of 1
    • Remove the following Phillips #00 screws from the left antenna:
    • One 2.6 mm screw
    • Two 1.5 mm screws
  2. iPad Mini 3 Left Antenna Cable Replacement: step 2, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 2, image 2 of 2
    • Use the flat end of a spudger to loosen the foam adhesive securing the Wi-Fi antenna to the left speaker.
  3. iPad Mini 3 Left Antenna Cable Replacement: step 3, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 3, image 2 of 2
    • Use the flat end of a spudger to fold the wide left-hand piece of tape away from the left speaker.
  4. iPad Mini 3 Left Antenna Cable Replacement: step 4, image 1 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 4, image 2 of 3 iPad Mini 3 Left Antenna Cable Replacement: step 4, image 3 of 3
    • Use the tip of a spudger to pry the antenna cable tape up from the rear case of the iPad.
    • Gently pull the antenna cable out of the way as you work along the piece of tape to free it and keep it from resealing.
  5. iPad Mini 3 Left Antenna Cable Replacement: step 5, image 1 of 2 iPad Mini 3 Left Antenna Cable Replacement: step 5, image 2 of 2
    • Pull the antenna cable from the clip behind the Lightning connector.
Sam Goldheart
471,486 Reputation
538 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,418 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 102
