iPad Mini 6 Battery Replacement
  1. iPad Mini 6 Battery Replacement, Apply tape to a cracked screen: step 1, image 1 of 3 iPad Mini 6 Battery Replacement, Apply tape to a cracked screen: step 1, image 2 of 3 iPad Mini 6 Battery Replacement, Apply tape to a cracked screen: step 1, image 3 of 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. iPad Mini 6 Battery Replacement, Heat the bottom edge: step 2, image 1 of 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. iPad Mini 6 Battery Replacement, Screen removal information: step 3, image 1 of 3 iPad Mini 6 Battery Replacement, Screen removal information: step 3, image 2 of 3 iPad Mini 6 Battery Replacement, Screen removal information: step 3, image 3 of 3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. iPad Mini 6 Battery Replacement, Insert an opening pick: step 4, image 1 of 3 iPad Mini 6 Battery Replacement, Insert an opening pick: step 4, image 2 of 3 iPad Mini 6 Battery Replacement, Insert an opening pick: step 4, image 3 of 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. iPad Mini 6 Battery Replacement, Separate the bottom adhesive: step 5, image 1 of 3 iPad Mini 6 Battery Replacement, Separate the bottom adhesive: step 5, image 2 of 3 iPad Mini 6 Battery Replacement, Separate the bottom adhesive: step 5, image 3 of 3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. iPad Mini 6 Battery Replacement, Heat the right edge: step 6, image 1 of 1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. iPad Mini 6 Battery Replacement, Separate the bottom-right corner adhesive: step 7, image 1 of 3 iPad Mini 6 Battery Replacement, Separate the bottom-right corner adhesive: step 7, image 2 of 3 iPad Mini 6 Battery Replacement, Separate the bottom-right corner adhesive: step 7, image 3 of 3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. iPad Mini 6 Battery Replacement, Separate the remaining adhesive: step 8, image 1 of 2 iPad Mini 6 Battery Replacement, Separate the remaining adhesive: step 8, image 2 of 2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. iPad Mini 6 Battery Replacement, Reposition the screen: step 9, image 1 of 3 iPad Mini 6 Battery Replacement, Reposition the screen: step 9, image 2 of 3 iPad Mini 6 Battery Replacement, Reposition the screen: step 9, image 3 of 3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. iPad Mini 6 Battery Replacement, Unfasten the display cable bracket: step 10, image 1 of 2 iPad Mini 6 Battery Replacement, Unfasten the display cable bracket: step 10, image 2 of 2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. iPad Mini 6 Battery Replacement, Remove the display cable bracket: step 11, image 1 of 2 iPad Mini 6 Battery Replacement, Remove the display cable bracket: step 11, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. iPad Mini 6 Battery Replacement, Disconnect the display: step 12, image 1 of 3 iPad Mini 6 Battery Replacement, Disconnect the display: step 12, image 2 of 3 iPad Mini 6 Battery Replacement, Disconnect the display: step 12, image 3 of 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. iPad Mini 6 Battery Replacement, Remove the screen: step 13, image 1 of 2 iPad Mini 6 Battery Replacement, Remove the screen: step 13, image 2 of 2
    • Remove the screen from the frame.
  14. iPad Mini 6 Battery Replacement, Disconnect the battery: step 14, image 1 of 2 iPad Mini 6 Battery Replacement, Disconnect the battery: step 14, image 2 of 2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  15. iPad Mini 6 Battery Replacement, Battery removal information: step 15, image 1 of 2 iPad Mini 6 Battery Replacement, Battery removal information: step 15, image 2 of 2
    Plastic Cards
    $2.99
    Buy
    • Before you begin the procedure, note the following:
    • There are four stretch release adhesive pull tabs that have to be removed to separate the adhesive underneath the battery.
    • The remainder of the adhesive is located on the top edge of the battery, near the connector; keep this in mind when inserting a plastic card.
  16. iPad Mini 6 Battery Replacement, Remove the stretch release adhesive: step 16, image 1 of 2 iPad Mini 6 Battery Replacement, Remove the stretch release adhesive: step 16, image 2 of 2
    Buy
    • Use tweezers, or your fingers, to grasp the black pull tab on one of the adhesive strips.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
  17. iPad Mini 6 Battery Replacement: step 17, image 1 of 3 iPad Mini 6 Battery Replacement: step 17, image 2 of 3 iPad Mini 6 Battery Replacement: step 17, image 3 of 3
    • Pull the strip out slowly and steadily at a low angle. Give it plenty of time to stretch and un-stick from under the battery.
    • If the adhesive strip breaks off, try to retrieve it using your fingers or blunt tweezers, and continue pulling—but do not pry under the battery.
    • Repeat the process on all four stretch release adhesive strips.
  18. iPad Mini 6 Battery Replacement, Apply isopropyl alcohol: step 18, image 1 of 1
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire. In case you're struggling to pull up the battery, apply more isopropyl alcohol and try again.
    • Apply a few drops of high concentration (over 90%) isopropyl alcohol to the gaps surrounding the battery's top edge.
  19. iPad Mini 6 Battery Replacement: step 19, image 1 of 2 iPad Mini 6 Battery Replacement: step 19, image 2 of 2
    • Tilt the top edge of the device upward to allow the isopropyl alcohol to work its way underneath the battery.
    • Hold for 1–2 minutes to allow time for the isopropyl alcohol to weaken the adhesive.
  20. iPad Mini 6 Battery Replacement, Separate the battery's adhesive: step 20, image 1 of 3 iPad Mini 6 Battery Replacement, Separate the battery's adhesive: step 20, image 2 of 3 iPad Mini 6 Battery Replacement, Separate the battery's adhesive: step 20, image 3 of 3
    • Insert a plastic card into the gap between the battery's top edge and the frame.
    • Use the plastic card to slice the adhesive underneath the battery.
  21. iPad Mini 6 Battery Replacement, Remove the battery: step 21, image 1 of 3 iPad Mini 6 Battery Replacement, Remove the battery: step 21, image 2 of 3 iPad Mini 6 Battery Replacement, Remove the battery: step 21, image 3 of 3
    • Pry up with the plastic card to separate the battery from the frame.
    • Remove the battery.
    • If there's any alcohol remaining, use a lint-free cloth to wipe it off or allow it to dry before installing a new battery.
    • During reassembly, remove the old adhesive and apply stretch release adhesive strips, double sided adhesive tape, or pre-cut adhesive to secure the new battery.
    • Do not reuse the battery after it has been removed, as doing so is a potential safety hazard.
For optimal performance, calibrate your newly installed battery after completing this guide.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPad mini 6 Answers community for help.
6 other people completed this guide.
Alex Diaz-Kokaisl
215,449 Reputation
1,046 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,790 Guides authored
3 Guide Comments
I hope you add a video to this amazing guide on replacing the battery and add a link on where to buy the battery. Thank you a million Macs!
AV Virtual Energy - Reply
Does the iPad come up with warnings about 3rd party battery installed ?
Robin Bonathan - Reply
On Step 3 you describe the screen once its removed. The "left edge" is actually the "right edge" when the screen is installed in the ipad. This could lead to some confusion.
Alexander - Reply
Past 24 Hours: 43
Past 7 Days: 247
Past 30 Days: 954
All Time: 25,162
