This teardown is not a repair guide. To repair your iPad Mini 7th Generation, use our service manual.
  1. iPad Mini 7th Generation Chip ID, Main Board Side 1: step 1, image 1 of 2 iPad Mini 7th Generation Chip ID, Main Board Side 1: step 1, image 2 of 2
    • Apple APL1V02 / 339S01476 A17 Pro hexa-core applications processor w/ penta-core GPU and Neural Engine layered over a SK hynix H58G66AK6HX132 8 GB LPDDR5 SDRAM memory
    • Kioxia K5A3XF2641 128 GB NAND flash memory
    • Apple APL109A / 343S00700 power management
    • Apple APL1099 / 343S00513 power management
    • Apple 338S00693-B0 power management
    • Texas Instruments SN2012027P USB type-C controller
    • Macronix MX25V8035F 1 MB serial NOR flash memory
  2. iPad Mini 7th Generation Chip ID: step 2, image 1 of 1
    • Texas Instruments SN2610A0 battery charger
    • Analog Devices MAX98728B audio amplifier
    • Broadcom BCM15900B0 touch controller
    • Texas Instruments LM3567A1 LED flash driver
    • Likely Texas Instruments TPS61280H battery front-end DC-DC converter
    • Texas Instruments TPS259481A 8 A eFuse w/ bidirectional power delivery
  3. iPad Mini 7th Generation Chip ID, Main Board Side 1 - Sensors: step 3, image 1 of 1
    • Bosch Sensortec accelerometer & gyroscope
    • Bosch Sensortec pressure sensor
  4. iPad Mini 7th Generation Chip ID, Main Board Side 1 - Connectivity: step 4, image 1 of 1
    • USI 339S01438 WiFi 6E & Bluetooth 5.3 controller
  5. iPad Mini 7th Generation Chip ID, Display Board Side 1: step 5, image 1 of 2 iPad Mini 7th Generation Chip ID, Display Board Side 1: step 5, image 2 of 2
    • Parade Technologies DP815-A0 timing controller
    • Renesas ISL98667A display power supply
    • STMicroelectronics M24128-DF 16 kB serial EEPROM memory
4 Guide Comments
Any idea of the cellular modem the iPad mini has?
Albus Brian - Reply Share
My question as well. What is the cellular modem chip in the iPad Mini 7 cellular model? Is it still the Qualcomm Snapdragon X60 used in the Mini 6 or is it the X75 used in the iPhone 16 Pro?
Michael Reynolds - Reply Share
The answer to my own question is, sources say, the Qualcomm X70 5G Modem
There is not modem chip in a ipad mini 7th gen if it's a wifi only version
Anas Jellouli - Share
Past 24 Hours: 10
Past 7 Days: 45
Past 30 Days: 248
All Time: 4,990
