iPad Mini CDMA Battery Connector Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPad Mini CDMA Battery Connector Replacement, Battery Connector: step 1, image 1 of 1
    • Remove the three 1.3 mm Phillips #00 screws securing the connector shield to the logic board.
    • Be sure to not substitute these three screws with any other screws, specifically the screws securing the LCD shield plate to the rear case of the iPad. Any slightly longer screws may strip the screw holes and result in irreparable damage to the logic board.
  2. iPad Mini CDMA Battery Connector Replacement: step 2, image 1 of 1
    Tool used on this step:
    Buy
    • Use a pair of tweezers to grasp and remove the connector shield from the iPad.
  3. iPad Mini CDMA Battery Connector Replacement: step 3, image 1 of 2 iPad Mini CDMA Battery Connector Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector and not on the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
Andrew Optimus Goldheart
512,538 Reputation
407 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 622
