iPad mini 4 LTE Display Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPad mini 4 LTE Display Assembly Replacement, Display Assembly: step 1, image 1 of 3 iPad mini 4 LTE Display Assembly Replacement, Display Assembly: step 1, image 2 of 3 iPad mini 4 LTE Display Assembly Replacement, Display Assembly: step 1, image 3 of 3
    • Use the pointed end of a spudger to disconnect the display data connector from its socket on the logic board.
    • Use the pointed end of a spudger to disconnect the digitizer cable connector from its socket on the logic board.
    • When reconnecting these, press down from one end of the connector to the other. If you press in the middle of the connector, you may bend it, causing damage or a poor connection.
  2. iPad mini 4 LTE Display Assembly Replacement: step 2, image 1 of 1
    • Remove the display assembly.
    • To reinstall your display assembly, you will need to replace the display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
Evan Noronha
228,238 Reputation
168 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 387
