iPhone 11 Pro Rear Case Replacement
Video Overview
  1. iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: step 1, image 1 of 2 iPhone 11 Pro Rear Case Replacement, Remove the pentalobe screws: step 1, image 2 of 2
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 6.7 mm-long pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    I am having difficulty accessing the disassembly steps to remove all of the components from the rear case. This web site stops at step 1. I am not sure how to access the rest of the steps. Can you help. Domingo Rochin
    Mingo59 - Reply
15 other people completed this guide.
Arty
27,604 Reputation
95 Guides authored
3 Comments
how much for housing iphone 11 pro ? Thank you
daddy - Reply
If yo buy it from indonesia it only cost you arround $100-$200
izaz adityas -
I ordered a new charging port but it doesn’t seem to include a speaker element on the left side, and the charging connector module above the port. Can those be moved over from the old charging port?
lemonlev - Reply
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 199
All Time: 19,461
