iPhone 15 Pro Max Screen Replacement
Clay Eickemeyer
Clay Eickemeyer and 4 other contributors
Last updated on March 5, 2025
1 - 2 hours
Moderate
Featured Guide
Introduction
Go to step 1
Use this guide to replace a broken or cracked screen in your iPhone 15 Pro Max.
You'll need replacement screen adhesive to complete this repair.
Note: Due to Apple's parts pairing restrictions, on iOS 17.6 and earlier, True Tone and auto brightness are disabled after a screen replacement, even when using an original Apple screen. On iOS 18 and newer, you can calibrate your new screen using Apple's Repair Assistant to restore functionality on genuine parts.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
  • iPhone 15 Pro Max Screen
Parts
Tools
Show more…
iFixit earns commission when you buy through these links.
  1. iPhone 15 Pro Max Screen Replacement, Prepare your phone for disassembly: step 1, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Prepare your phone for disassembly: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 15 Pro Max Screen Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 15 Pro Max Screen Replacement, Mark your opening picks: step 3, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Mark your opening picks: step 3, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Reply
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Reply
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Reply
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Reply
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Reply
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Reply
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Reply
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Reply
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Reply
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Reply
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Reply
  4. iPhone 15 Pro Max Screen Replacement, Remove the pentalobe screws: step 4, image 1 of 1
    • Use a P2 pentalobe driver to remove the two 7.2 mm-long screws on either side of the charging port.
  5. iPhone 15 Pro Max Screen Replacement, Secure the back glass: step 5, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Secure the back glass: step 5, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Secure the back glass: step 5, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open the screen, you need to secure the back glass with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the back glass to secure it.
  6. iPhone 15 Pro Max Screen Replacement, Secure an Anti-Clamp: step 6, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Secure an Anti-Clamp: step 6, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Secure an Anti-Clamp: step 6, image 3 of 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the screen facing up, slide the arms over the left edge of your phone, with one suction cup on the screen and the other on the back glass. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 15 Pro Max Screen Replacement, Create a gap under the screen: step 7, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Create a gap under the screen: step 7, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Create a gap under the screen: step 7, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they tend to slip, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may use your hands to clean the suction cups and warm them up to help them stick.
  8. iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 8, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 8, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 8, image 3 of 3
    • Use a hair dryer or heat gun to heat the bottom edge of the screen until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the screen and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti-Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 15 Pro Max Screen Replacement, Heat the bottom edge: step 9, image 1 of 1
  10. iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 10, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 10, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Insert an opening pick: step 10, image 3 of 3
    • Apply a suction handle to the bottom edge of the screen.
    • Pull up on the handle with a strong, steady force to create a gap between the screen and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 15 Pro Max Screen Replacement, Screen information: step 11, image 1 of 1
    • As you slice the adhesive securing the screen in the next steps, be careful of the following areas:
    • There are two delicate cables connecting the screen to the phone: one just above the action button, and the other near the middle of the left edge.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in these locations to avoid bending the contacts.
    触点被弄断了 怎么办??
    Chris008 - Reply
  12. iPhone 15 Pro Max Screen Replacement, Separate the bottom edge adhesive: step 12, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Separate the bottom edge adhesive: step 12, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Separate the bottom edge adhesive: step 12, image 3 of 3
    • Don't insert your opening pick deeper than 3 mm along the bottom edge.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from re-sealing.
  13. iPhone 15 Pro Max Screen Replacement, Heat the right edge: step 13, image 1 of 1
    • Heat the right edge of the screen until it's hot to the touch.
  14. iPhone 15 Pro Max Screen Replacement, Position the opening pick: step 14, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Position the opening pick: step 14, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Position the opening pick: step 14, image 3 of 3
    • Don't insert your pick deeper than 5 mm along the right edge.
    • Slide your pick around the bottom right corner of the screen and toward the power button until you feel a hard stop at a clip securing the screen.
    • Rotate your pick so the flat edge is under the screen.
  15. iPhone 15 Pro Max Screen Replacement, Release the right clip: step 15, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Release the right clip: step 15, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Release the right clip: step 15, image 3 of 3
    • Twist the pick to increase the gap between the screen and the frame until the right clip releases.
    • Insert a second opening pick to the right of the first pick.
  16. iPhone 15 Pro Max Screen Replacement, Separate the right edge adhesive: step 16, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Separate the right edge adhesive: step 16, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Separate the right edge adhesive: step 16, image 3 of 3
    • Slide the first pick back to the bottom right corner of the screen.
    • Slide the second pick to the top right corner of the screen to separate the adhesive.
    • Leave these picks inserted to prevent the adhesive from resealing.
  17. iPhone 15 Pro Max Screen Replacement, Heat the top edge: step 17, image 1 of 1
    • Heat the top edge of the screen until it's hot to the touch.
  18. iPhone 15 Pro Max Screen Replacement, Separate the top edge adhesive: step 18, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Separate the top edge adhesive: step 18, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Separate the top edge adhesive: step 18, image 3 of 3
    • Don't insert your pick deeper than 3 mm along the top edge.
    • Slide your pick around the top right corner and along the top edge to release the two clips and adhesive securing it.
  19. iPhone 15 Pro Max Screen Replacement, Heat the left edge: step 19, image 1 of 1
    • Heat the left edge of the screen until it's hot to the touch.
  20. iPhone 15 Pro Max Screen Replacement, Separate the left edge adhesive: step 20, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Separate the left edge adhesive: step 20, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Separate the left edge adhesive: step 20, image 3 of 3
    • Don't insert your pick deeper than 2 mm along the left edge to avoid the two cables connecting the screen to the phone.
    • Rotate your pick around the top left corner of the screen.
    • Slide your pick to the bottom left corner of the screen to separate the adhesive.
  21. iPhone 15 Pro Max Screen Replacement, Swing open the screen: step 21, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Swing open the screen: step 21, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Swing open the screen: step 21, image 3 of 3
    • Gently swing open the screen to the left of the phone.
    • If the screen feels stuck, go back around the perimeter to check for missed sections of adhesive or stuck clips.
    • Rest the screen against a box or similar object so it doesn't strain the cables.
  22. iPhone 15 Pro Max Screen Replacement, Unfasten the logic board cover: step 22, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Unfasten the logic board cover: step 22, image 2 of 2
    FixMat
    $36.95
    • Use a tri-point Y000 driver to remove the six screws securing the logic board cover:
    • One 2.1 mm‑long screw
    • Five 1.5 mm‑long screws
  23. iPhone 15 Pro Max Screen Replacement, Remove the logic board cover: step 23, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Remove the logic board cover: step 23, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Remove the logic board cover: step 23, image 3 of 3
    • Use tweezers or your fingers to grab and slide the logic board cover toward the bottom of the phone to clear the sensor cable.
    • Remove the cover.
  24. iPhone 15 Pro Max Screen Replacement, Disconnect the battery: step 24, image 1 of 3 iPhone 15 Pro Max Screen Replacement, Disconnect the battery: step 24, image 2 of 3 iPhone 15 Pro Max Screen Replacement, Disconnect the battery: step 24, image 3 of 3
    • Use the tip of an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over its socket and gently press down on one side until it clicks into place, then press down on the other side. Make sure it sits flat, as the insulating rubber around the sockets might prevent it from connecting fully.
  25. iPhone 15 Pro Max Screen Replacement, Disconnect the ambient light sensor: step 25, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Disconnect the ambient light sensor: step 25, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the ambient light sensor press connector from the top left of the logic board.
  26. iPhone 15 Pro Max Screen Replacement, Disconnect the screen: step 26, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Disconnect the screen: step 26, image 2 of 2
    • Disconnect the screen press connector.
  27. iPhone 15 Pro Max Screen Replacement, Remove the screen: step 27, image 1 of 2 iPhone 15 Pro Max Screen Replacement, Remove the screen: step 27, image 2 of 2
    • Remove the screen.
    • During reassembly, stop here and use this guide to install new screen adhesive.
    • Be careful not to damage any of the spring contacts as you clean the frame.
    The new screen I got didn't include the flex cable at the top right of the back of the screen. The guide should include a procedure for transferring that (proximity sensor?) flex cable to the new screen.
    Telogor - Reply
After your repair, depending on the replacement part, you may be able to calibrate it using Apple's Repair Assistant, available as of iOS 18. Update your device, navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
18 other people completed this guide.
Clay Eickemeyer
81,653 Reputation
455 Guides authored
Guide Team Member of Guide Team
Staff
9 Members
11,379 Guides authored
2 Comments
Can you fix my IPhone?
Jose Vargas - Reply
Muy buenos instrucciones
Mateo ramirez - Reply
Past 24 Hours: 131
Past 7 Days: 966
Past 30 Days: 3,553
All Time: 44,595
