iPhone 16 Loudspeaker Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 16 Loudspeaker Removal, Before you begin: step 1, image 1 of 2 iPhone 16 Loudspeaker Removal, Before you begin: step 1, image 2 of 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Loudspeaker Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Loudspeaker Removal, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Loudspeaker Removal, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Loudspeaker Removal, Remove the pentalobe screws: step 3, image 2 of 2
    • Use a P2 pentalobe driver to remove the two 7.7 mm-long screws on either side of the charging port.
  4. iPhone 16 Loudspeaker Removal, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Loudspeaker Removal, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Loudspeaker Removal, Mark your opening picks: step 4, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  5. iPhone 16 Loudspeaker Removal, Secure the screen: step 5, image 1 of 3 iPhone 16 Loudspeaker Removal, Secure the screen: step 5, image 2 of 3 iPhone 16 Loudspeaker Removal, Secure the screen: step 5, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next four steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down four steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • The Anti-Clamp applies suction to both the screen and the back glass. To open only the back glass, you need to secure the screen with tape. You can also check out the full instructions on how to use this tape.
    • Cut two strips of tape, apply them along the long edges of the phone, and fold them over the screen to secure it.
    • Make sure the tape is only securing the screen and not the back glass.
  6. iPhone 16 Loudspeaker Removal, Secure an Anti-Clamp: step 6, image 1 of 3 iPhone 16 Loudspeaker Removal, Secure an Anti-Clamp: step 6, image 2 of 3 iPhone 16 Loudspeaker Removal, Secure an Anti-Clamp: step 6, image 3 of 3
    • Pull the Anti-Clamp's blue handle backward to unlock the arms.
    • With the back glass facing up, slide the arms over the right edge of your phone, with one suction cup on the back glass and the other on the screen. Center the suction cups near the bottom edge.
    • Support your phone so it rests level while between the Anti-Clamp's arms—a small box works well.
    • Squeeze the cups together to create suction.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, use tape to create a grippier surface.
  7. iPhone 16 Loudspeaker Removal, Create a gap under the back glass: step 7, image 1 of 3 iPhone 16 Loudspeaker Removal, Create a gap under the back glass: step 7, image 2 of 3 iPhone 16 Loudspeaker Removal, Create a gap under the back glass: step 7, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle one full turn (360 degrees) or until the cups start to stretch.
    • As the cups stretch, make sure they stay vertically aligned with each other. If they keep slipping, remove the Anti-Clamp and apply tape for the cups to stick to.
    • If you don't have tape, you may warm up the suction cups to help them stick.
  8. iPhone 16 Loudspeaker Removal, Insert an opening pick: step 8, image 1 of 2 iPhone 16 Loudspeaker Removal, Insert an opening pick: step 8, image 2 of 2
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
    • Wait up to a minute for the adhesive to separate and a gap to form between the back glass and the frame.
    • If a gap doesn't appear after one minute, apply more heat and rotate the handle a quarter turn. Let the Anti‑Clamp and time do the work for you.
    • Insert an opening pick into the gap.
    • Remove the Anti-Clamp using the pull tabs on the suction cups.
    • Skip the next two steps.
  9. iPhone 16 Loudspeaker Removal, Heat the bottom edge: step 9, image 1 of 1
    iOpener
    $12.99
    Buy
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  10. iPhone 16 Loudspeaker Removal, Insert an opening pick: step 10, image 1 of 3 iPhone 16 Loudspeaker Removal, Insert an opening pick: step 10, image 2 of 3 iPhone 16 Loudspeaker Removal, Insert an opening pick: step 10, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass.
    • While supporting the frame with one hand, pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  11. iPhone 16 Loudspeaker Removal, Back glass information: step 11, image 1 of 1
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the phone, right next to the volume down button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the phone.
  12. iPhone 16 Loudspeaker Removal, Heat the right edge: step 12, image 1 of 1
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  13. iPhone 16 Loudspeaker Removal, Separate the bottom right adhesive: step 13, image 1 of 3 iPhone 16 Loudspeaker Removal, Separate the bottom right adhesive: step 13, image 2 of 3 iPhone 16 Loudspeaker Removal, Separate the bottom right adhesive: step 13, image 3 of 3
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick around the bottom right corner and to the volume down button to separate the adhesive and release the metal clip.
    • Don't slide past the volume buttons to avoid damaging the wireless charging cable.
    • You'll hear and feel the metal clip release as you pass it.
    • Leave this pick inserted to prevent the adhesive from resealing.
  14. iPhone 16 Loudspeaker Removal, Heat the left edge: step 14, image 1 of 1
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  15. iPhone 16 Loudspeaker Removal, Separate the left adhesive: step 15, image 1 of 3 iPhone 16 Loudspeaker Removal, Separate the left adhesive: step 15, image 2 of 3 iPhone 16 Loudspeaker Removal, Separate the left adhesive: step 15, image 3 of 3
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  16. iPhone 16 Loudspeaker Removal, Heat the top edge: step 16, image 1 of 1
    • Use a hair dryer or heat gun to heat the top edge of the back glass until it's hot to the touch.
  17. iPhone 16 Loudspeaker Removal, Separate the top right adhesive: step 17, image 1 of 3 iPhone 16 Loudspeaker Removal, Separate the top right adhesive: step 17, image 2 of 3 iPhone 16 Loudspeaker Removal, Separate the top right adhesive: step 17, image 3 of 3
    • Slide your second opening pick around the top left corner and along the top edge to separate the adhesive and release the metal clips.
    • Continue sliding your pick around the top right corner until you reach the Action button.
  18. iPhone 16 Loudspeaker Removal, Reposition the back glass: step 18, image 1 of 3 iPhone 16 Loudspeaker Removal, Reposition the back glass: step 18, image 2 of 3 iPhone 16 Loudspeaker Removal, Reposition the back glass: step 18, image 3 of 3
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the phone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
    • Remove the opening picks before continuing.
  19. iPhone 16 Loudspeaker Removal, Remove the middle connector cover screws: step 19, image 1 of 2 iPhone 16 Loudspeaker Removal, Remove the middle connector cover screws: step 19, image 2 of 2
    • Use a tri-point Y000 driver to remove the two 1 mm‑long screws securing the middle connector cover.
  20. iPhone 16 Loudspeaker Removal, Remove the middle connector cover: step 20, image 1 of 3 iPhone 16 Loudspeaker Removal, Remove the middle connector cover: step 20, image 2 of 3 iPhone 16 Loudspeaker Removal, Remove the middle connector cover: step 20, image 3 of 3
    • Insert the point of a spudger in either cutout on the middle connector cover.
    • Slide the cover towards the left edge of the phone and release its hook from its slot on the logic board.
    • Remove the cover.
  21. iPhone 16 Loudspeaker Removal, Disconnect the battery: step 21, image 1 of 2 iPhone 16 Loudspeaker Removal, Disconnect the battery: step 21, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  22. iPhone 16 Loudspeaker Removal, Disconnect the wireless charging coil: step 22, image 1 of 2 iPhone 16 Loudspeaker Removal, Disconnect the wireless charging coil: step 22, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the wireless charging coil press connector.
  23. iPhone 16 Loudspeaker Removal, Remove the back glass: step 23, image 1 of 1
    • Lift the back glass off the frame and remove it.
  24. iPhone 16 Loudspeaker Removal, Remove the loudspeaker screws: step 24, image 1 of 2 iPhone 16 Loudspeaker Removal, Remove the loudspeaker screws: step 24, image 2 of 2
    • Remove the five screws securing the loudspeaker:
    • Two 1.5 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 2.9 mm‑long Phillips screw
    • One 1.2 mm‑long tri‑point Y000 screw
  25. iPhone 16 Loudspeaker Removal, Remove the loudspeaker: step 25, image 1 of 3 iPhone 16 Loudspeaker Removal, Remove the loudspeaker: step 25, image 2 of 3 iPhone 16 Loudspeaker Removal, Remove the loudspeaker: step 25, image 3 of 3
    • Use the point of a spudger to lift the loudspeaker out of the frame.
    • Remove the loudspeaker.
Finish Line
Alex Diaz-Kokaisl
163,138 Reputation
769 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,533 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 77
All Time: 110
