iPhone 16 Pro Max Back Glass Replacement
  1. iPhone 16 Pro Max Back Glass Replacement, Before you begin: step 1, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement, Before you begin: step 1, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement, Before you begin: step 1, image 3 of 3
    • Allow your iPhone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your iPhone.
    • Hold the power and either volume buttons, and slide to power off your iPhone.
  2. iPhone 16 Pro Max Back Glass Replacement, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Tape over any cracks: step 2, image 2 of 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Max Back Glass Replacement, Remove the pentalobe screws: step 3, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Remove the pentalobe screws: step 3, image 2 of 2
    • Use a P2 pentalobe driver to remove the two 7.4 mm-long screws on either side of the charge port.
  4. iPhone 16 Pro Max Back Glass Replacement, Mark your opening picks: step 4, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement, Mark your opening picks: step 4, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement, Mark your opening picks: step 4, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  5. iPhone 16 Pro Max Back Glass Replacement, Create a gap using a suction handle: step 5, image 1 of 1
    Tool used on this step:
    iOpener
    $14.99
    Buy
    • The next two steps show how to create an initial gap using a suction handle.
    • Use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • You can also use an iOpener to heat the back glass. Follow these instructions to heat and apply the iOpener properly.
  6. iPhone 16 Pro Max Back Glass Replacement: step 6, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement: step 6, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement: step 6, image 3 of 3
    • Apply a suction handle to the bottom edge of the back glass.
    • Pull up on the handle with strong, steady force to create a gap between the back glass and the frame.
    • If a gap doesn't appear, apply more heat to the edge and try again.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Max Back Glass Replacement, Back glass information: step 7, image 1 of 1
    • As you slice the adhesive securing the back glass in the following steps, don't insert your pick deeper than 3 mm to avoid damaging the following areas:
    • A delicate cable connecting the back glass to the iPhone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • Multiple spring contacts around the perimeter of the iPhone.
  8. iPhone 16 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Separate the bottom edge adhesive: step 8, image 2 of 2
    • Slide the opening pick along the bottom edge to slice the adhesive.
    • If the adhesive feels difficult to slice, reheat the edge for a minute and try again.
    • Leave the opening pick in the bottom-left corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Max Back Glass Replacement, Heat the left edge: step 9, image 1 of 1
    • Use a hair dryer or heat gun to heat the left edge of the back glass until it's hot to the touch.
  10. iPhone 16 Pro Max Back Glass Replacement, Separate the left adhesive: step 10, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Separate the left adhesive: step 10, image 2 of 2
    • Insert a second opening pick into the bottom-left corner, close to the existing pick.
    • Don't insert your pick deeper than 3 mm to avoid damaging the spring contacts.
    • Slide your pick along the left edge to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted in the top-left corner to prevent the adhesive from resealing.
  11. iPhone 16 Pro Max Back Glass Replacement, Heat the top edge and corner: step 11, image 1 of 1
    • Use a hair dryer or heat gun to heat the top edge and top-right corner of the back glass until it's hot to the touch.
  12. iPhone 16 Pro Max Back Glass Replacement, Separate the top adhesive: step 12, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Separate the top adhesive: step 12, image 2 of 2
    • Insert a third opening pick into the top-left corner.
    • Slide the opening pick along the top edge and around the top-right corner, stopping above the volume up button.
    • Leave this pick inserted to prevent the adhesive from resealing.
  13. iPhone 16 Pro Max Back Glass Replacement, Heat the right edge: step 13, image 1 of 1
    • Use a hair dryer or heat gun to heat the right edge of the back glass until it's hot to the touch.
  14. iPhone 16 Pro Max Back Glass Replacement, Separate the right adhesive: step 14, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Separate the right adhesive: step 14, image 2 of 2
    • Insert a fourth opening pick into the bottom-right corner.
    • Slide the opening pick around the corner and up the right edge, stopping below the volume down button.
  15. iPhone 16 Pro Max Back Glass Replacement, Reposition the back glass: step 15, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement, Reposition the back glass: step 15, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement, Reposition the back glass: step 15, image 3 of 3
    • At this point, the back glass should be free from the frame. If the back glass feels stuck, go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • Swing open the back glass to the right of the iPhone to separate the remaining adhesive.
    • Support the back glass with a clean, sturdy object.
  16. iPhone 16 Pro Max Back Glass Replacement, Remove the battery connector cover: step 16, image 1 of 1
    • Use a tri-point Y000 driver to remove the three screws securing the battery connector cover:
    • Two 1.3 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Max Back Glass Replacement: step 17, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 17, image 2 of 2
    • Lift and remove the battery connector cover.
  18. iPhone 16 Pro Max Back Glass Replacement, Disconnect the battery: step 18, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Disconnect the battery: step 18, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
  19. iPhone 16 Pro Max Back Glass Replacement, Remove the back glass connector cover: step 19, image 1 of 1
    • Use a tri-point Y000 driver to remove the four screws securing the back glass connector cover:
    • Two 1.0 mm‑long screws
  20. iPhone 16 Pro Max Back Glass Replacement: step 20, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 20, image 2 of 2
    • Lift the back glass connector cover straight up and remove it.
  21. iPhone 16 Pro Max Back Glass Replacement, Remove the back glass: step 21, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Remove the back glass: step 21, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the back glass connector.
  22. iPhone 16 Pro Max Back Glass Replacement: step 22, image 1 of 1
    • Remove the back glass.
  23. iPhone 16 Pro Max Back Glass Replacement, Disassembly complete: step 23, image 1 of 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your iPhone.
    • Depending on your iPhone model, some reassembly photos may have minor visual discrepancies. The procedure, however, will be correct for your iPhone.
  24. iPhone 16 Pro Max Back Glass Replacement, Remove the leftover adhesive: step 24, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement, Remove the leftover adhesive: step 24, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement, Remove the leftover adhesive: step 24, image 3 of 3
    Buy
    • Work around the fragile grounding clips as you're cleaning the frame. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Use blunt nose tweezers or your fingers to remove large pieces of adhesive from the frame perimeter.
    • Use a spudger to scrape the adhesive residue off of the frame.
    • If the adhesive feels stubborn, apply some heat using a hair dryer or heat gun and try again.
  25. iPhone 16 Pro Max Back Glass Replacement, Clean the back glass: step 25, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Clean the back glass: step 25, image 2 of 2
    Microfiber Cleaning Cloths
    $3.99
    Buy
    • If you're reusing your back glass, apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to a microfiber or lint-free cloth and wipe around the perimeter to prepare the surface for new adhesive.
  26. iPhone 16 Pro Max Back Glass Replacement, Clean the frame: step 26, image 1 of 1
    • Wrap a lint-free cloth or a coffee filter over the point of a spudger and apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to it.
    • Wipe in one direction along the perimeter of the frame to clean the adhesive residue.
    • Take your time doing this. A clean frame allows replacement adhesive to lay evenly, ensuring a better bond.
  27. iPhone 16 Pro Max Back Glass Replacement, Apply the replacement adhesive: step 27, image 1 of 1
    • Lay the adhesive sheet over the frame to determine its proper orientation.
    • Use features such as the camera cutout and notches along the top and bottom edges to visualize how the adhesive will lay in the frame.
  28. iPhone 16 Pro Max Back Glass Replacement: step 28, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 28, image 2 of 2
    • Grab the tab in the corner of the adhesive sheet and peel the liner to expose a third of the adhesive.
    • The exposed adhesive is very sticky. Don't let it touch anything until you're ready to apply it to the frame.
    • If your adhesive has multiple liners, peel the liner that exposes the side that sticks to the frame.
  29. iPhone 16 Pro Max Back Glass Replacement: step 29, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement: step 29, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement: step 29, image 3 of 3
    • Carefully align the exposed edge of the adhesive strip with the corresponding edge of the iPhone's frame.
    • Once the adhesive is pressed into place, you can't reposition it—you'll have to remove it and start over with new adhesive.
    • When it's correctly aligned, gently press the exposed adhesive strip onto the frame.
  30. iPhone 16 Pro Max Back Glass Replacement: step 30, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement: step 30, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement: step 30, image 3 of 3
    • Continue peeling away the liner from the adhesive, gently pressing the adhesive into place.
    • If you've correctly aligned the adhesive, the edges will fall perfectly into place.
    • If your adhesive is slightly misaligned, gently pull the long edges into alignment with the frame.
    • If the adhesive begins to crease or wrinkle, remove it and start over with fresh adhesive.
    • If you don't have another set of adhesive strips handy, it's okay to temporarily put your iPhone back together and use it normally without any adhesive. Just keep in mind that your iPhone's water resistance will be compromised until you replace the adhesive.
  31. iPhone 16 Pro Max Back Glass Replacement: step 31, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 31, image 2 of 2
    • Use a spudger to press the adhesive around the entire perimeter of your iPhone.
    • Work around the fragile grounding clips. If you bend one out of place, gently bend it back with your fingers or tweezers.
    • Don't press too hard, or you'll stretch and deform the adhesive.
  32. iPhone 16 Pro Max Back Glass Replacement: step 32, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement: step 32, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement: step 32, image 3 of 3
    • Use a spudger or your fingers to lift the pull tab connected to the large front liner. The pull tab is often in a corner of the liner.
    • Use the pull tab to peel off the large front liner from the adhesive.
    • At this point, you may still have liner covering the perimeter, which prevents the adhesive from accidentally sticking to anything while you're reassembling your iPhone. Don't remove these small release liners just yet.
  33. iPhone 16 Pro Max Back Glass Replacement, Connect the back glass: step 33, image 1 of 1
    • Prop up the back glass along the right edge of your iPhone.
  34. iPhone 16 Pro Max Back Glass Replacement: step 34, image 1 of 1
    • Use your finger or the flat end of a spudger to press and connect the back glass connector onto the logic board.
  35. iPhone 16 Pro Max Back Glass Replacement, Connect the battery: step 35, image 1 of 1
    • Use your finger or a spudger to press and connect the battery press connector onto the logic board.
    • This is a good point to test your repair before sealing up your iPhone. Power on your iPhone and make sure it works as expected. Power it back down and continue reassembly.
    • If your iPhone doesn't turn on, connect it to a power source and try again.
    • If you've replaced the logic board and the screen fails to turn on, you'll need to follow the screen guide to manually connect the display connector.
  36. iPhone 16 Pro Max Back Glass Replacement, Install the connector covers: step 36, image 1 of 1
    • Align the back glass connector cover by its screw holes and lay it in place.
  37. iPhone 16 Pro Max Back Glass Replacement: step 37, image 1 of 1
    • Use a tri-point Y000 driver to install the four screws securing the back glass connector cover:
  38. iPhone 16 Pro Max Back Glass Replacement: step 38, image 1 of 1
    • Align the battery connector cover by its screw holes and lay it in place.
  39. iPhone 16 Pro Max Back Glass Replacement: step 39, image 1 of 1
    • Use a tri-point Y000 driver to install the three screws securing the battery connector cover:
  40. iPhone 16 Pro Max Back Glass Replacement, Remove the final adhesive liners: step 40, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Remove the final adhesive liners: step 40, image 2 of 2
    • Use your fingers or a spudger to peel away all perimeter liners, exposing the adhesive.
    • As you remove the liners, make sure nothing touches the exposed adhesive.
    • Check the frame and back glass for any stray liners and remove them. There should be no liners remaining.
  41. iPhone 16 Pro Max Back Glass Replacement: step 41, image 1 of 3 iPhone 16 Pro Max Back Glass Replacement: step 41, image 2 of 3 iPhone 16 Pro Max Back Glass Replacement: step 41, image 3 of 3
    • Lower the back glass onto the frame, beginning with the top edge.
    • If you feel resistance, a perimeter clip may have bent out of place and is being crushed by the frame. Look at the point of resistance and gently straighten any bent clips.
    • Press along the edges of the iPhone until the back glass sits flush against the frame.
  42. iPhone 16 Pro Max Back Glass Replacement, Apply heat to the perimeter: step 42, image 1 of 1
    • Use a hair dryer, heat gun, or an iOpener to heat the back glass perimeter until it's slightly too hot to touch.
    • The heat softens the adhesive and helps create a better bond.
  43. iPhone 16 Pro Max Back Glass Replacement, Apply pressure to the perimeter: step 43, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Apply pressure to the perimeter: step 43, image 2 of 2
    • Use your fingers to firmly squeeze around the perimeter of the iPhone.
  44. iPhone 16 Pro Max Back Glass Replacement: step 44, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 44, image 2 of 2
    • Place your iPhone screen-side down on a clean, flat work surface.
    • Lay a strip of tape around the perimeter of the back glass to protect the finish.
    • Stack coins around the perimeter of the back glass until you create a wall that's as tall as the rear camera protrusions.
    • Alternatively, you can use vise clamps around the perimeter of your device to set the new adhesive.
  45. iPhone 16 Pro Max Back Glass Replacement: step 45, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement: step 45, image 2 of 2
    • Place 3-4 heavy books squarely on top of your iPhone.
    • The coins may leave a slight impression on the bottom book cover, so don't use anything valuable.
    • Leave the books in place for about 30 minutes.
    • The pressure will help activate the adhesive.
  46. iPhone 16 Pro Max Back Glass Replacement, Install the pentalobe screws: step 46, image 1 of 2 iPhone 16 Pro Max Back Glass Replacement, Install the pentalobe screws: step 46, image 2 of 2
    • Use a P2 pentalobe driver to install the two 7.4 mm-long screws on either side of the charge port.
After your repair, calibrate a genuine replacement part using Apple's Repair Assistant. Navigate to Settings General About Parts & Service History, tap Restart & Finish Repair, and follow the onscreen prompts.
13 other people completed this guide.
Arthur Shi
314,654 Reputation
729 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
4 Guide Comments
Gracias por todo lo que hacen por los demás. Dios me los bendiga
Pedro Herrera - Reply
coooool but l need help because its broken like broken
sappy - Reply
Very well explained but after watching this and seeing how easily something else could get damaged and then what it costs for the tools versus having Apple Store replace the glass. I will let them do the job professionally. Thank you. It was interesting.
Mike - Reply
iPhone15ライトブルーの背面ガラスの純正品を探しているのですが、どこから購入が可能でしょうか?
kazuya - Reply
Past 24 Hours: 130
Past 7 Days: 774
Past 30 Days: 2,977
All Time: 42,255
