iPhone 16 Pro Max Front Camera Installation
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 16 Pro Max Front Camera Installation, Install the front camera assembly: step 1, image 1 of 2 iPhone 16 Pro Max Front Camera Installation, Install the front camera assembly: step 1, image 2 of 2
    • Lay the front camera assembly in its recess.
    • Gently tuck the camera flex cables into the gap between the rear camera assembly and the earpiece speaker assembly.
  2. iPhone 16 Pro Max Front Camera Installation: step 2, image 1 of 2 iPhone 16 Pro Max Front Camera Installation: step 2, image 2 of 2
    • Use your finger or a spudger to press and connect the two camera connectors onto the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down in the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  3. iPhone 16 Pro Max Front Camera Installation: step 3, image 1 of 1
    • Use your finger or a spudger to press and connect the earpiece speaker and the mmWave antenna connectors onto the logic board.
Finish Line
Arthur Shi
316,637 Reputation
730 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,987 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 49
