Introduction
Steps to remove the logic board for the iPhone 16 Pro Max.
Includes its own earpiece speaker steps (instead of the prereq) because this version has the mmWave antenna attached to the earpiece speaker. The earpiece guide has the mmWave removed, causing a visual discrepancy.
Use the point of a spudger to pry up and disconnect the earpiece speaker and 5G mmWave antenna press connectors.
Use a spudger to pry up and disconnect the seven silver press connectors from the top of the logic board.
This image shows the display connector underneath the logic board. The next two steps show how to disconnect this connector from the bottom of the logic board.
Insert the flat edge of an opening pick between the battery and the left edge of the logic board. Hold the pick in place with your fingers.
Insert the flat end of a spudger underneath the right edge of the logic board.
Gently pry with the spudger to lift the logic board and disconnect the display connector.
