iPhone 16 Pro Max Rear Camera Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. iPhone 16 Pro Max Rear Camera Removal, Remove the rear camera assembly: step 1, image 1 of 3 iPhone 16 Pro Max Rear Camera Removal, Remove the rear camera assembly: step 1, image 2 of 3 iPhone 16 Pro Max Rear Camera Removal, Remove the rear camera assembly: step 1, image 3 of 3
    • Use the point of a spudger to pry up and disconnect the first rear camera connector.
    • Disconnect the second camera connector underneath the first connector.
  2. iPhone 16 Pro Max Rear Camera Removal: step 2, image 1 of 1
    • Use a Phillips screwdriver to remove the two 2.9 mm‑long screws securing the rear camera assembly.
  3. iPhone 16 Pro Max Rear Camera Removal: step 3, image 1 of 3 iPhone 16 Pro Max Rear Camera Removal: step 3, image 2 of 3 iPhone 16 Pro Max Rear Camera Removal: step 3, image 3 of 3
    • Be careful not to touch any of the camera lens. If you do, carefully wipe the lens with a lint-free cloth.
    • Insert the tip of a spudger under the top edge of the rear camera assembly.
    • Pry up the assembly to loosen it from the frame.
    • Remove the rear camera assembly.
Finish Line
Arthur Shi
283,026 Reputation
587 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,533 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 43
All Time: 72
