iPhone 16 Pro Microphone Removal
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 16 Pro Microphone Removal, Prepare the phone for disassembly: step 1, image 1 of 2 iPhone 16 Pro Microphone Removal, Prepare the phone for disassembly: step 1, image 2 of 2
    • Allow the phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from the phone.
    • Hold the power and either volume buttons and slide to power off the phone.
  2. iPhone 16 Pro Microphone Removal, Tape over any cracks: step 2, image 1 of 2 iPhone 16 Pro Microphone Removal, Tape over any cracks: step 2, image 2 of 2
    • If the screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Microphone Removal, Mark your opening picks: step 3, image 1 of 3 iPhone 16 Pro Microphone Removal, Mark your opening picks: step 3, image 2 of 3 iPhone 16 Pro Microphone Removal, Mark your opening picks: step 3, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Microphone Removal, Remove the pentalobe screws: step 4, image 1 of 2 iPhone 16 Pro Microphone Removal, Remove the pentalobe screws: step 4, image 2 of 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Microphone Removal, Mark your opening picks: step 5, image 1 of 3 iPhone 16 Pro Microphone Removal, Mark your opening picks: step 5, image 2 of 3 iPhone 16 Pro Microphone Removal, Mark your opening picks: step 5, image 3 of 3
    • Apple sells an Adhesive Cutter tool for cutting the display adhesive safely in their Self Repair Store.
  6. iPhone 16 Pro Microphone Removal, Remove the microphone: step 6, image 1 of 2 iPhone 16 Pro Microphone Removal, Remove the microphone: step 6, image 2 of 2
    • Remove the three screws securing the microphone:
    • One 3.6 mm‑long standoff screw
    • One 2.9 mm‑long standoff screw
    • One 1.3 mm‑long tri-point Y000 screw
  7. iPhone 16 Pro Microphone Removal: step 7, image 1 of 2 iPhone 16 Pro Microphone Removal: step 7, image 2 of 2
    • Use the flat end of a spudger to pry up the microphone until you can grab it with your fingers or tweezers.
    • Don't pry against the battery, or you may damage it.
    • You'll feel some resistance as the microphone releases from its frame gasket.
  8. iPhone 16 Pro Microphone Removal: step 8, image 1 of 3 iPhone 16 Pro Microphone Removal: step 8, image 2 of 3 iPhone 16 Pro Microphone Removal: step 8, image 3 of 3
    • Pull the microphone towards the battery to separate it from its adhesive gasket holding it to the frame.
    • Remove the microphone.
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Nick Schultz
38,204 Reputation
226 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,829 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 53
