LG env2 vx9100 Side Buttons Replacement
  1. LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 1 of 3 LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 2 of 3 LG env2 vx9100 Side Buttons Replacement, Battery: step 1, image 3 of 3
    • Power off the phone before disassembly to avoid electric shock or fire.
    • Place the phone face down on the table.
    • Pull down the tab below the battery with your fingernail or an opening tool.
    • Lift the battery out.
  2. LG env2 vx9100 Side Buttons Replacement, Back Panel: step 2, image 1 of 2 LG env2 vx9100 Side Buttons Replacement, Back Panel: step 2, image 2 of 2
    • Locate the five rubber covers on the back panel of the phone.
    • Use a metal probe to remove each rubber cover and expose the screws underneath.
  3. LG env2 vx9100 Side Buttons Replacement: step 3, image 1 of 2 LG env2 vx9100 Side Buttons Replacement: step 3, image 2 of 2
    • Locate the six 2.5-millimeter Phillips #00 screws on the back panel.
    • Remove all six screws with a Phillips #00 screwdriver.
  4. LG env2 vx9100 Side Buttons Replacement: step 4, image 1 of 2 LG env2 vx9100 Side Buttons Replacement: step 4, image 2 of 2
    • Locate the seam around the edge of the phone.
    • Insert a plastic opening tool into the seam and gently pry to release the tabs.
    • Work around the phone until all tabs are released.
    • Remove the back panel.
  5. LG env2 vx9100 Side Buttons Replacement, Side Buttons: step 5, image 1 of 2 LG env2 vx9100 Side Buttons Replacement, Side Buttons: step 5, image 2 of 2
    • Locate the volume and camera buttons on the right side of the phone.
    • Lift up on the buttons to slide them out of the phone.
Reed Williston
34 Reputation
7 Guides authored
Cal Poly, Team 16-55, Forte Fall 2012 Member of Cal Poly, Team 16-55, Forte Fall 2012
CPSU-FORTE-F12S16G55
5 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 8
All Time: 591
