Nexus 7 Speaker Cable Replacement
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Nexus 7 Speaker Cable Replacement, Speaker Cable: step 1, image 1 of 1
    • Peel back the copper ESD shielding covering the bottom of the motherboard.
    • Do not try to remove the copper shielding, as it is still attached underneath the battery.
    • If you're just replacing the micro usb charge port, there is no need to peel back the copper heatsink like in the photo, the speaker assembly can simply be moved out of the way once unscrewed. If the speakers are to be replaced simply peel back the bottom corner to expose the speaker connection. Leave the rest of the heatsink shield alone.
  2. Nexus 7 Speaker Cable Replacement: step 2, image 1 of 1
    • Using the tip of a spudger, push the speaker cable straight out of its socket on the motherboard.
Brett Hartt
129,827 Reputation
143 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,468 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 7
All Time: 51
