HP Stream 8 Speakers Replacement
  1. HP Stream 8 Speakers Replacement, Midframe: step 1, image 1 of 1
    • Use your nail or a spudger to pry the back cover off of the device.
  2. HP Stream 8 Speakers Replacement: step 2, image 1 of 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Speakers Replacement: step 3, image 1 of 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Speakers Replacement: step 4, image 1 of 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Speakers Replacement, Speakers: step 5, image 1 of 2 HP Stream 8 Speakers Replacement, Speakers: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Locate the two speakers at the bottom of the device.
    • Remove the two speakers by prying them out using a pair of tweezers.
    • Detach the red and black power wiring from the device and pull the speakers entirely out of the HP Stream 8.
    • Remember where the red and black wiring is connected to the device.
    • The power wires are soldered to the device and will be difficult to detach.
  6. HP Stream 8 Speakers Replacement: step 6, image 1 of 1
    • Grab the two replacement speakers and the soldering iron.
    • Locate where the red and black power wiring previously connected to the device.
    • Attach and re-solder the red and black power wiring.
    • For soldering help, check out iFixit's How to Solder and Desolder Connections guide.
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 338
