iPhone 6 Plus Anti-Clamp Opening Procedure
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp instructions: step 1, image 1 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp instructions: step 1, image 2 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure, Anti-Clamp instructions: step 1, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  2. iPhone 6 Plus Anti-Clamp Opening Procedure: step 2, image 1 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure: step 2, image 2 of 3 iPhone 6 Plus Anti-Clamp Opening Procedure: step 2, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick or tool under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 60
All Time: 799
