MacBook Pro 13" Unibody Early 2011 Lower Case Replacement
  1. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement, Lower Case: step 1, image 1 of 1
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
  2. MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: step 2, image 1 of 2 MacBook Pro 13" Unibody Early 2011 Lower Case Replacement: step 2, image 2 of 2
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
60 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 47
All Time: 36,916
