iPhone 8 Back Glass Replacement
Video Overview
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: step 1, image 1 of 1
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. iPhone 8 Back Glass Replacement: step 2, image 1 of 2 iPhone 8 Back Glass Replacement: step 2, image 2 of 2
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: step 3, image 1 of 1
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Finish Line
14 other people completed this guide.
Phryne
21,441 Reputation
18 Guides authored
1 Guide Comment
Where does it show the replacement I only see the removal?
ManDeen - Reply
Past 24 Hours: 12
Past 7 Days: 55
Past 30 Days: 220
All Time: 58,573
