iPhone 8 Plus Display Assembly Replacement
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
  1. iPhone 8 Plus Display Assembly Replacement, Display Assembly: step 1, image 1 of 2 iPhone 8 Plus Display Assembly Replacement, Display Assembly: step 1, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
  2. iPhone 8 Plus Display Assembly Replacement: step 2, image 1 of 2 iPhone 8 Plus Display Assembly Replacement: step 2, image 2 of 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
  3. iPhone 8 Plus Display Assembly Replacement: step 3, image 1 of 2 iPhone 8 Plus Display Assembly Replacement: step 3, image 2 of 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
  4. iPhone 8 Plus Display Assembly Replacement: step 4, image 1 of 1
    • Remove the bracket covering the front panel sensor assembly connector.
  5. iPhone 8 Plus Display Assembly Replacement: step 5, image 1 of 2 iPhone 8 Plus Display Assembly Replacement: step 5, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
  6. iPhone 8 Plus Display Assembly Replacement: step 6, image 1 of 1
6 other people completed this guide.
Jeff Suovanen
447,958 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
123 Members
23,828 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 14
All Time: 4,486
