iPhone 8 Plus Wi-Fi Diversity Antenna Flex
Jeff Suovanen
Jeff Suovanen and 3 other contributors
Last updated on June 19, 2024
1 hour
Moderate
Introduction
Go to step 1
Use this guide to replace the small flex cable running from the Lightning connector flex to the logic board in the iPhone 8 Plus. Replacing it may resolve a number of connectivity issues.
Parts
Tools
Show more…
  1. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Pentalobe Screws: step 1, image 1 of 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    what do I do about super stripped screws?
    Ean Palacios - Reply
    I’m sorry, your comment slipped past my radar earlier. For future fixers that might see this and ask the same question, you can check out our stripped screw guide for some detailed advice.
    Adam O'Camb -
    Do you need a toolkit like the essential toolkit
    Adam Palmer - Reply
    Hi Adam. Having a tool kit with all of the listed parts above is best. The screw heads are very small and each set of screws needs a very specific type of driver to remove them without stripping any of them.
    Kyle Luksa -
  2. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Mark your opening picks: step 2, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Mark your opening picks: step 2, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Mark your opening picks: step 2, image 3 of 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Reply
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Reply
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Reply
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Reply
    the picture shows 3 cm but the description says 3 mm's. Which one is it?
    John Pena - Reply
    That is a misunderstanding. It is a ruler with a scale for cm, it shows 0.3 cm, i.e. 3 mm.
    VauWeh -
    Oh, come ON!
    Big Ed -
    It will ALWAYS be millimeters on a phone, but this step is ridiculous, skip it!
    Leif DeWolf -
    It's not an Ifixit KIT if it doesn't include everything. You'll need to order the opening pic separately. Or head to Walmart like myself and look for guitar pics. Hopefully, this will work just as well.
    Jaleeljb97@icloud.com - Reply
    No pick in mine as well. It’s really not clear that you have to order this separately when ordering an IPhone SE 202/2022 screen repair kit. Is this the case?
    Jackson Castiglione - Reply
    Frustrated, I ordered a compact package where everything was encapsulated. Useless suction tools could not separate the screen. If it is unable to decouple the screen, then why sucking suction tools you have provided.
    Shourob Datta - Reply
    For my kit the triangle pick was stuck inside the box with the screen not with the other tools maybe it's also there for you
    Henry Scheibehenne - Reply
    Y’all are getting far, FAR too detailed with some of this stuff…. Measuring and marking the pick that you won’t actually use to open the device?!? lol that’s kinda funny. Just heat it up, grab a spudger, and the back just pops right off! The iFixit tech need to stick to the KISS method more often, you know KEEP IT SIMPLE STUPID!!! Like l, for reals, I’ve been doing this stuff for YEARS and using iFixit guides regularly and this is just ridiculous at this point!
    Leif DeWolf - Reply
    Will the phone still work if the sensor assembly on the back of the screen is damaged?
    Mutshidzi Rambau - Reply
  3. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Tape over any cracks: step 3, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Tape over any cracks: step 3, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Tape over any cracks: step 3, image 3 of 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Anti-Clamp instructions: step 4, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Anti-Clamp instructions: step 4, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Anti-Clamp instructions: step 4, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 5, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 5, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 5, image 3 of 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Bien, y a-t-il des boutiques spécialisées elle-même se charger de l’opération de changement de l’écran de l’iPhone 8 plus je suis un littéraire. Je renonce à le faire moi-même mais j’assume les frais le prix de l’écran. Merci de répondre dans un commentaire suivant Cordialement
    Acquaviva - Reply
  6. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 6, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 6, image 2 of 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 7, image 1 of 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
    6/14/23 I did this repair but used a heat gun on low for 60 seconds. This allowed me to open the case as the instructions say, but in the end the Home button failed. I probably over heated it. I used this "go around" for a virtual Home button. I don't care about touch ID:
    https://www.youtube.com/watch?v=LbTlUm4p...
    laryball - Reply
  8. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 8, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 8, image 2 of 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Warning ! If you pull too hard (reheat the underside of the display again), you create an gap of air between the glass and the lcd display !
    When you replace the display assembly you end up with gray stains on the display.
    Result: you have to buy a new display (assembly).
    Arnoud - Reply
    Using just the single suction cup that is included in the battery replacement kit probably wouldn’t open the device. An iOpener and an iSlack should be the recommended method. However, you can get it open with just the single suction cup and iOpener, but does take a lot of time.
    Get an iOpener and iSlack with the battery replacement kit.
    Chris - Reply
    I used a flat x-acto (#18) blade knife tool to gently pry back the screen enough to allow me to insert the pick near the bottom corner. I then worked the pick under the screen as mentioned in steps 5 & 6 below then. This worked really well for me.
    Kyle Luksa - Reply
    I used the suction cup without heating the phone - the adhesive came away quite easily without applying any heat. Maybe due to age of phone (nearly 4 years old). Worth trying.
    Ben Vinnerd - Reply
    I can’t get the single suction cup to work. Hate being stuck on the simplest step!
    Donny - Reply
    My screen was very shattered, and was quite hard to get suction, as my tape was very low quality. However, after pulling it up a little bit, I was able to insert a regular razor blade into the very small gap and used that as a lever.
    Michael Scroop - Reply
    Oh my goodness! Don't do that again. You can definitely damage something in the phone if you use a sharp metal razor blade..
    cytur -
  9. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 9, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 9, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 9, image 3 of 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    After multiple tries and using a very hot iOpener, it will not open.
    Kenneth Ewald, Sr. - Reply
    In sheer frustration, I pulled out my trusty pocket knife and managed to lift the bottom of the screen slightly, but in the process, cracked the glass from the bottom to the home button. The case is open now.
    this was by far the most difficult part. be diligent and follow the “firm and constant pressure” guide... the “gap” will be extremely “slight”. you will be able to slide a corner of the pry tool even if you cannot see the gap.
    Colleen V - Reply
    This needs a TON of strength and most likely a partner. Your strong partner will pull up the screen with the suction cup and you will put the pick into the small gap that appears.
    cytur - Reply
  10. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 10, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 10, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 10, image 3 of 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    Do not go over the top otherwise you can crack the screen. Sadly happened to me :(
    The instruction should be:
    “Stop near BUT BEFORE REACHING the top left corner of the display”
    Leonardo Piga - Reply
  11. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Screen information: step 11, image 1 of 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 12, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 12, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 12, image 3 of 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    I had really good luck using a hairdryer on some of the more stubborn portions of adhesive.
    Jessica Kirsh - Reply
  13. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 13, image 1 of 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 14, image 1 of 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 15, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 15, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 15, image 3 of 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    Be very careful at this step. The glass at the top will break very easy when the display is lifted too much.
    Gerdschi D - Reply
  16. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 16, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 16, image 2 of 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 17, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 17, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 17, image 3 of 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Das “links” ist auf dem Foto rechts.
    Matze Diamond - Reply
    Das ist falsch. Wenn man auf das iPhone sieht, ist der Home Button unten. Auf dem Photo ist deutlich sichtbar, dass die linke Seite angehoben wird.
    Hans - Reply
  18. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Battery Disconnection: step 18, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Battery Disconnection: step 18, image 2 of 2
    Magnetic Project Mat
    $19.95
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    The Phillips screwdriver bit is the PH000. The measurement refers to the screw length.
    Jack Harry - Reply
  19. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 19, image 1 of 1
    • Remove the lower display cable bracket.
  20. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 20, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 20, image 2 of 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    When I reassembled the iPhone 8 Plus, I had to plug it into a Lightning cable to wake it up (just pushing power button wasn’t sufficient).
    browniestarmite - Reply
  21. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Display Assembly: step 21, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Display Assembly: step 21, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I got hold of a iPhone 8 Plus with cracked screen that I am planning to fix.
    Here is my problem:
    When I tried to take out the screen from my phone, (step 15-18) I was curious about the new screen, so I tried to connect it. It was completely dead! Then I tried the old cracked one, and suddenly that was dead to! This is a phone that some fool has been inside earlier and changed battery, but I suspect he has done some more really stupid things. The Taptic Engine is living its own life and vibrating every time I slightly touch the home button. (I have a new Taptic Engine) The phone is also full of dust and small particles that does not belong there. One tri-point Y000 screw (step 18) is even missing! Now the biggest problem is that both screens are black! I know the phone is on, because I hear voice command speak when I turn on the power. The screen worked before I tried to change it? And one last thing: My new LCD screen came with new flex cables. Is it possible to switch over, so I can use the old ones?
    smikalsen - Reply
    Hi,
    Is your problem solved?
    Daniel Leprince -
    Be careful of damaging MOSFETs by the LH side of the large lower display cable. After replacing the battery and turning the device on, the phone showed low charge and didn't have a charging symbol even after plugging into multiple cables and chargers. Turns out I had damaged the logic board attempting to disconnect the connector.
    Chris Cerrudo - Reply
  22. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 22, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 22, image 2 of 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
    I used the other end of the spudger on this connector and it seemed to work a little better for me. I came in from underneath the top-right edge instead of the bottom right.
  23. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 23, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 23, image 2 of 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
    una vite da 1mm e due viti da 1.2 mm???
    Matteo Carachino - Reply
    Ciao Matteo! Grazie per l’osservazione. Ho appena modificato il testo :) La traduzione è aperta a tutti. Hai quindi la possibilità di fare le tue suggestione direttamente nel testo e sei il benvenuto se vuoi usare di questa possibilità nel futuro. Grazie ancora per la vigilanza! Saluti, Claire
    Claire Miesch -
    The tool kit does include a 1.0 or1.2mm screwdriver! How am I supposed to remove those screws?
    peter frommer - Reply
    Bought the screwdriver that supposedly fits these screws and it still doesn’t work.
    hypercarduser - Reply
    My bracket looks different. Can’t get these screws out.
    Ray Rushing - Reply
    kit came with wrong bit. i received 2x P02 (penta tips) and no tri point y000.
    Christopher Shane Gripp - Reply
    There is no such thing as a trigger point y000 screwdriver. Why couldn't they use Philips like the rest of the screws.Nobody knows what these trips point y000 even look like. this is a scam to force you to buy a new phone.
    Al tb - Reply
    y000 tri-point screw driver comes with the iFixit repair kit at minimal cost
    godo - Reply
  24. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 24, image 1 of 1
    • Remove the bracket covering the front panel sensor assembly connector.
  25. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 25, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 25, image 2 of 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
    What happens is this strip is torn and how does one fix it
    Mijinyawa Dauda - Reply
  26. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 26, image 1 of 1
    Should there be a step somewhere in here to point out when to remove the blue plastic from the new iFixit screen?
    Paul Santora - Reply
  27. iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Wi-Fi Diversity Antenna: step 27, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex, Wi-Fi Diversity Antenna: step 27, image 2 of 2
    • Remove the three screws securing the L-shaped bracket next to the Taptic Engine:
    • One 1.3 mm Y000 screw
    • One 2.6 mm Phillips screw
    • One 3.5 mm Phillips screw
    De Y000 schroef nam meteen ook de  2.4 mm standoff-schroef aan de achterzijde mee. Wat lastig om die uit elkaar te halen.
    nilsplackle - Reply
  28. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 28, image 1 of 1
    • Remove the bracket.
  29. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 29, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 29, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 29, image 3 of 3
    • Use an opening pick to gently separate the adhered portion of the antenna flex cable from the top surface of the speaker.
    • This portion of the flex cable is lightly adhered in place. If necessary, apply a little heat from an iOpener or hair dryer to soften the adhesive. This makes it easier to separate (and re-adhere) the flex cable safely.
    should i be worried if the piece with the two holes broke off
    Robert Quinn - Reply
  30. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 30, image 1 of 2 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 30, image 2 of 2
    • Use the point of a spudger to pry up and disconnect the antenna flex cable from the logic board.
  31. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 31, image 1 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 31, image 2 of 3 iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 31, image 3 of 3
    • Use the point of your spudger to pry up and disconnect the other end of the antenna flex cable from its socket, next to the Lightning Port.
    • Reconnecting this cable can be tricky. Make it easier by using your tweezers to hold the flex cable so the connector aligns with its socket. Then, gently press down on the connector with the flat of your spudger until it clicks into place.
    I was unable to plug this back in when re-assembling. My home button doesn’t work anymore. The connector it was supposed to plug into seems to spin around.
    Dan Putnam - Reply
    I had a similar experience during this repair. My problem was that the nib on the ribbon that actually connects in to the socket came off the ribbon cable when I initially detached the cable. I didn’t realize this until after the repair, but I also had to replace the Wifi Diversity cable entirely. A tell-tale sign is that you don’t receive good cell reception.
    Lucas -
    I did not notice until reassembly, but the antenna socket pulled off the board. I have no micro-soldering tools. The friction of the connector was greater than the solder holding it in place.
    David Hampson - Reply
    The little connector in the first picture ripped the component off the circuit board when trying to pry it up so be careful. I’m guessing it’s like a previous poster said and the socket is stronger than the glue/material that holds the component to the PCB. This was on a new board during disassembly trying to locate a potential problem. Phone still workings with WiFi and cellular normally but the cellular signal is down about 1/3 on average wherever I am.
    J.Garrecht Metzger - Reply
    Calling this step tricky is an understatement 😅
    cytur - Reply
    Mine broke too and wifi still works fine
    Does this have anything to donwith upper speaker connection?
    Umit Battal - Reply
  32. iPhone 8 Plus Wi-Fi Diversity Antenna Flex: step 32, image 1 of 1
    • Remove the Wi-Fi diversity antenna.
    This had a little adhesive on the metal band. Couldn’t just pluck it out as shown. What I did worked but what I should’ve done is run my blue puck up and down the length.
    Mark Hintze - Reply
    I followed these steps to this point and maybe applied force in the wrong spot or too much force and it appears that when I loosened the wifi diversity antenna from the socket below the Taptic Engine module, it came up with the socket detached from the logic board. Did I just really screw up my iPhones WiFi capability?
    Joel Potter - Reply
18 other people completed this guide.
Jeff Suovanen
439,286 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,416 Guides authored
4 Comments
My Cellular data connection keeps connecting and disconnecting consistently. I received a message “Could not activate cellular data network”'.
WiFi and Bluetooth work fine. Could this possibly fix my issue or is it more of motherboard issue?
Thank you if anyone can help. My phone is out of warranty
Sammy S - Reply
Same problem. Any solutions? Thank you.
Wanjoo Kim -
So I broke the plug in on the logic board where you plug in for WiFi, is that fixable . Oh I broke the plug in for the LED light also
Jose Perez - Reply
This is cellular antenna btw.
Harri Iivonen - Reply
Past 24 Hours: 4
Past 7 Days: 35
Past 30 Days: 149
All Time: 29,792
