Introduction
iPhone XS Max uses both the primary loudspeaker and the earpiece speaker together to produce stereo sound. Use this guide to replace the primary loudspeaker at the bottom of the phone only. Replacing this speaker can help resolve issues such as loss of sound, poor sound quality, and distorted sound.
Power off your iPhone before beginning disassembly.
Remove the two 6.9 mm-long pentalobe screws at the bottom edge of the iPhone.
Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
Measure 3 mm from the tip and mark the opening pick with a permanent marker.
How to break your phone more like i probably just buy another one its not worth the hassle geometry dash 2.2
Person who doesn’t know how to read a ruler.
Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
Tool used on this step:Clampy - Anti-Clamp$24.95
Pull the blue handle backwards to unlock the Anti-Clamp's arms.
Slide the arms over either the left or right edge of your iPhone.
Position the suction cups near the bottom edge of the iPhone—one on the front, and one on the back.
Squeeze the cups together to apply suction to the desired area.
Heat an iOpener and thread it through the arms of the Anti-Clamp.
Fold the iOpener so it lays on the bottom edge of the iPhone.
Wait one minute to give the adhesive a chance to release and present an opening gap.
Insert an opening pick into the gap under the screen and the plastic bezel, not the screen itself.
Skip the next three steps.
Use a hairdryer or heat gun or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
Tool used on this step:Magnetic Project Mat$19.95
Remove four Y000 screws securing the logic board cover bracket, of the following lengths:
Two 1.1 mm screws
One 1.5 mm screw
One 3.7 mm screw
Remove the five 1.4 mm tri-point Y000 screws securing the bracket below the Taptic Engine and main speaker.
21 other people completed this guide.
if you think ThelmA`s story is neAt three weeks Ago my cousinns step-dAAd got $7275 just sitting there eleven hours A week from there ApArtment And they're clAssmAte's sister`s neighbour did this for eight months And got pAid over $7275 pArt time from their pc. Applie the steps AvAilAble here,,, HERE☛ www.jobsbud.com
LelaDFarrell - Reply
If the screen has gone 'black', there's no way to turn it off?
pvillave - Reply
Use & do this to restore 'True Tone' functionality:
https://www.youtube.com/watch?v=JT5EpIbX...
pvillave - Reply
"Note: True Tone functionality is disabled after a screen replacement, even when using an original Apple screen."
Unless: I bought a Chinese digital tool that 'restores' the True Tone function of the screen. It will intake the code from
your original screen, then program your new screen with the same code. Worked like a charm for me & it was easy!
Product is called 'REWA' & you have to get '2' pieces...First is the programmer device...Second is the connector piece that
the screen cable connects to....the one I got will do iPhone 6x up to iPhone 11x. REWA info on YouTubeVideo--> JT5EpIbXs2I
pvillave - Reply
