iPod 2nd Generation Rear Panel Replacement
  1. iPod 2nd Generation Rear Panel Replacement, Rear Panel: step 1, image 1 of 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod 2nd Generation Rear Panel Replacement: step 2, image 1 of 1
    • Opening the iPod can be challenging. Don't get discouraged if it takes a few tries before the iPod is opened.
    • Insert a plastic iPod opening tool in the seam between the white plastic front and metal back of the iPod. Once you've inserted the tool, run it along the seam to free the five tabs holding the iPod together.
  3. iPod 2nd Generation Rear Panel Replacement: step 3, image 1 of 1
    • Continue to run the opening tool along the side of the case until all five tabs have been released.
  4. iPod 2nd Generation Rear Panel Replacement: step 4, image 1 of 1
    • Work around the corner of the iPod and release the two tabs holding the iPod together near the dock connector.
  5. iPod 2nd Generation Rear Panel Replacement: step 5, image 1 of 1
    • Free the five tabs holding the iPod together on the other side. You may be able to free the tabs by gently wiggling the front panel of the iPod.
  6. iPod 2nd Generation Rear Panel Replacement: step 6, image 1 of 1
    • Lift the rear panel away from the iPod, making sure it doesn't catch on the headphone jack.
4 other people completed this guide.
iRobot
1 Reputation
635 Guides authored
2 Guide Comments
According to this site: https://www.lifewire.com/history-ipod-cl.... The thickness of the various HD sizes is different.
“4 x 2.4 x 0.78 inches - 5 GB Model
4 x 2.4 x 0.72 inches - 10 GB Model
4 x 2.4 x 0.84 inches - 20 GB Model”
It makes some sense from other information I’ve read, but I don’t find any discussion of a thick and thin version. Is the back for the 20GB model thicker/deeper than the 10GB model? Thanks for another great guide.
Rusty Lingenfelter - Reply
no, the model is same. but 2gen is a little thicker than 1 gen. apple use diffrent types of rubber cushion to fits in it. if you want change a bigger disk, make sure there is enugh space for battery
张兴潼 -
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 6,745
