iPod Nano 4th Generation Click Wheel Replacement
Views: 151K
View statistics:
Past 24 Hours:
6
Past 7 Days:
54
Past 30 Days:
336
All Time:
150,555
Comments: 110
107 comments on steps, 3 guide comments.
Go to guide comments
Completed: 54
54 people have marked this guide "completed." Will you be next?
Favorites: 25
25 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 - 4 hours
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replace a broken click wheel to regain control of your Nano.
Tools
    1. iPod Nano 4th Generation Click Wheel Replacement, Glass Panel: step 1, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement, Glass Panel: step 1, image 2 of 2
      • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
      • Pry the top bezel off the adhesive securing it to the display retainer.
      • At this point the hold switch slider is free and may fall. Be careful not to lose it.
      Ask FixBot
    2. iPod Nano 4th Generation Click Wheel Replacement: step 2, image 1 of 1
      • Remove the hold switch slider from the top of the Nano.
      Ask FixBot
    3. iPod Nano 4th Generation Click Wheel Replacement: step 3, image 1 of 1
      • Remove the two angled Phillips screws from the two corners of the display retainer.
      • These screw heads are extremely small and easily stripped.
      Ask FixBot
    4. iPod Nano 4th Generation Click Wheel Replacement: step 4, image 1 of 1
      • Insert an iPod opening tool between the outer case and the display retainer.
      • Use the tool to slide the display assembly out of the case slightly.
      • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
      • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
      Ask FixBot
    5. iPod Nano 4th Generation Click Wheel Replacement: step 5, image 1 of 1
      • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
      • Do not put unnecessary tension on the very thin display data cable.
      Ask FixBot
    6. iPod Nano 4th Generation Click Wheel Replacement: step 6, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement: step 6, image 2 of 2
      • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
      • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
      Ask FixBot
    7. iPod Nano 4th Generation Click Wheel Replacement: step 7, image 1 of 1
      • Lift the glass panel out of the Nano.
      • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
      Ask FixBot
    1. iPod Nano 4th Generation Click Wheel Replacement, Display: step 8, image 1 of 1
      • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
      • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
      Ask FixBot
    2. iPod Nano 4th Generation Click Wheel Replacement: step 9, image 1 of 1
      • Peel back the Kapton tape covering the display data cable socket.
      Ask FixBot
    3. iPod Nano 4th Generation Click Wheel Replacement: step 10, image 1 of 1
      • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
      Ask FixBot
    4. iPod Nano 4th Generation Click Wheel Replacement: step 11, image 1 of 1
      • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
      • Be careful not to rip the display data cable.
      Ask FixBot
    5. iPod Nano 4th Generation Click Wheel Replacement: step 12, image 1 of 1
      • Pull the display out of the Nano, minding the hold switch cable that may get caught.
      • As you pull the display out of the case, be careful not to break the hold switch cable.
      Ask FixBot
    1. iPod Nano 4th Generation Click Wheel Replacement, Logic Board Assembly: step 13, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement, Logic Board Assembly: step 13, image 2 of 2
      • Insert an iPod opening tool between the bottom bezel and the dock connector.
      • Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
      Ask FixBot
    2. iPod Nano 4th Generation Click Wheel Replacement: step 14, image 1 of 1
      • Remove the three Phillips screws along the bottom of the Nano.
      • The slightly longer of the three screws belongs in the middle.
      Ask FixBot
    3. iPod Nano 4th Generation Click Wheel Replacement: step 15, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement: step 15, image 2 of 2
      • Use an iPod opening tool to pry the aluminum dock bezel out of the Nano.
      • The dock bezel is very thin cast aluminum. To avoid breaking it, do not excessively flex it during removal.
      Ask FixBot
    4. iPod Nano 4th Generation Click Wheel Replacement: step 16, image 1 of 3 iPod Nano 4th Generation Click Wheel Replacement: step 16, image 2 of 3 iPod Nano 4th Generation Click Wheel Replacement: step 16, image 3 of 3
      • Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
      • The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
      • Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
      Ask FixBot
    5. iPod Nano 4th Generation Click Wheel Replacement: step 17, image 1 of 1
      • Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
      Ask FixBot
    6. iPod Nano 4th Generation Click Wheel Replacement: step 18, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement: step 18, image 2 of 2
      • Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
      Ask FixBot
    7. iPod Nano 4th Generation Click Wheel Replacement: step 19, image 1 of 1
      Tool used on this step:
      Buy
      • Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
      • Before proceeding, be sure that both the click wheel ribbon cable socket and its cable are freed from the adhesive securing them to the dock connector and logic board.
      • Peel back the cable on both ends!
      Ask FixBot
    8. iPod Nano 4th Generation Click Wheel Replacement: step 20, image 1 of 1
      • Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
      • When reassembling, ensure the click wheel cable is toward the front of the Nano and not in the grooves on the side. If it is in the groove you will probably cut it while sliding the logic board into place.
      Ask FixBot
    1. iPod Nano 4th Generation Click Wheel Replacement, Click Wheel: step 21, image 1 of 2 iPod Nano 4th Generation Click Wheel Replacement, Click Wheel: step 21, image 2 of 2
      • Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
      • This requires a good amount of force. Work slowly.
      • It may be helpful to use an edged tool to separate the adhesive from the click wheel on the inside of the Nano while pressing it down from the outside.
      • Remove the click wheel from the inside of the Nano.
      • Be careful not to let the click-wheel slide on the metal plate supporting it, as it will break the flat cable. Apply force perpendicular to the click-wheel.
      Ask FixBot
54 other people completed this guide.
3 Guide Comments
Hello, does anybody know where to fin a clickwheel replacement for the nano 4th gen ? I can't seem to find it on the internet, the only sellers who did have it in stock was on alibaba, and he said to me there were not any left when I contacted him.
Emmanuel Neff - Reply Share
Sure! My favorite site is EOE or elite obsolete electronics. They have a lot of click wheels. Additionally, you can find a lot on eBay for a few dollars.
Ad123re - Reply Share
This is the best set of instructions I’ve read regarding anything in the past 9 or 10 years. They are clearly stated, grammar is perfect and perfectly proofread before being published. It’s fits with the quality of simple writing I grew up with in the 50’s and 60’s and haven’t seen or read in the past many, many years. Nothing I’ve had to use over recent years (generally from China) comes close. This level of quality alone gives me confidence in the company itself.
Gary Blunk - Reply Share
Past 24 Hours: 6
Past 7 Days: 54
Past 30 Days: 336
All Time: 150,555
