iPod Nano 5th Generation Click Wheel Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
16
All Time:
1,427
Comments: 8
8 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Prerequisite Only This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Introduction
Go to step 1 ↓
A prerequisite for removing the logic board assembly.
Tools
    1. iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: step 1, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement, Click Wheel: step 1, image 2 of 2
      • Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
      • Use a low heat setting and do not hold the heat gun in place for too long to avoid melting the plastic bezel.
      • Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
      Ask FixBot
    2. iPod Nano 5th Generation Click Wheel Replacement: step 2, image 1 of 3 iPod Nano 5th Generation Click Wheel Replacement: step 2, image 2 of 3 iPod Nano 5th Generation Click Wheel Replacement: step 2, image 3 of 3
      • Unscrew three screws from the bottom of the iPod:
      • Two 4.4 mm angled Phillips screws
      • One 5.4 mm Phillips screw.
      • These screws may not come out on their own, so be sure not to lose them when removing the retainer.
      • Use a plastic opening tool to pry the metal retainer out from the bottom of the iPod and remove it.
      Ask FixBot
    3. iPod Nano 5th Generation Click Wheel Replacement: step 3, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 3, image 2 of 2
      • Insert a metal spudger into the slot at the bottom of the iPod just above the dock connector.
      • Use the metal spudger to pry up the bottom edge of the click wheel.
      Ask FixBot
    4. iPod Nano 5th Generation Click Wheel Replacement: step 4, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 4, image 2 of 2
      • Place a guitar pick between the click wheel and the case of the Nano and remove the metal spudger.
      • Pry up the edges of the click wheel with the guitar pick until the click wheel comes free from the case.
      • Do not try to completely remove the click wheel yet, as it is still held in place by a ribbon cable.
      Ask FixBot
    5. iPod Nano 5th Generation Click Wheel Replacement: step 5, image 1 of 2 iPod Nano 5th Generation Click Wheel Replacement: step 5, image 2 of 2
      • Lift the click wheel out of the way with one hand and use a plastic opening tool to pry the click wheel ribbon cable connector off its socket on the logic board.
      • Remove the click wheel.
      Ask FixBot
Matthew Newsom
43,123 Reputation
67 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 1,427
